Review - Bodor Laser BCL1309XU - Page 15
Page 15 of 15 FirstFirst ... 512131415
Results 169 to 170 of 170
Thread: Review - Bodor Laser BCL1309XU
  1. #169
    Jan 2007
    Not really. Bitmaps don't produce as clean engravings as vectors do, plus they scale in size with no lack of detail.
    Wade
    Quote Originally Posted by Zootalaws View Post
    Seems like a lot of work, where editing the vector fill for the boat to a solid colour would take seconds and leave you with the original vector for cutting. Or... take a copy, bitmap it and lay it on top of your boat/gradient.
  2. #170
    Jun 2012
    Brunei Darussalam
    Default Re: Review - Bodor Laser BCL1309XU
    Haven't you got that the wrong way round? Bitmaps don't scale without interpolation. Vectors scale infinitely, with no loss of detail.
    I was commenting on how you take a vector, convert it to bitmap just to remove the gradient which would cause you problems - if you just removed the gradient from the original vector, you would negate having to do that whole process.
    If you need mixed cutting/engraving, you can solid-fill your vector shape with whatever colour is relevant to your engraving power..
