Hi Norbert, Yes, there is two USB ports on the DSP controller, the normal one on the top, we use flesh memory to copy code files.
The other one is square, at the bottom, we use it to connect to the computer, you will receive a USB cable which can connect the DSP to the computer, we also use it to transmit the code files in to the DSP incase we dont have an USB flash memory. there should be a CD with DSP install program, you install the program in the computer, then connect the DSP, you can transmit the code file into the DSP, and you also can change some settings from this program. Notice that, with the DSP there is only 128M memory, I suggest you prepare some USB memory to use.
you will study them easily when you receive the machine.
And I will be happy to help if you have any problem.
Roc
www.roc-tech.net
