there are a couple of ways
1 we are in columbia and would just need on for the template
2 try shopbots forum on finding a shopbotter in your area, theres a guy in fountain inn that does this
jim mcgrew
www.mcgrewwoodwork.com
hello all,
not sure if this is the correct area of the forum to post these questions but hoping im in the ballpark and someone can give me some guidance. i am looking to have a set of speaker faces cnc machined from solid stock walnut lumber. the original faces are made of plastic and i would like to these duplicated in the wood. i assume they can probe the originals and then cut from the solid stock. i am located in between charlotte and atlanta so i figure there must be some company in that range that would do a limited run of say 10 of these for me. the diminsions are roughly 10" by about 48". any input on how i should pursue this? any links to someone with a diy machine capable of doing this or a company that takes on smaller orders like this? any help greatly appreicated
jim mcgrew
