5-axis self build?
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
Thread: 5-axis self build?
    Jul 2004
    Portugal
    Question 5-axis self build?
    Hello to you all.
    I’m new in the group. I’m from Portugal and I’ve been caught by the “CNC virus”...
    I intend to make large scale car models in foam. A starting point, to make very accurate 1/3 scale car models in fibreglass.
    I bought a couple of months ago, a little CNC machine from Roland. It’s a MDX20 model, and it has 200x150x65mm working volume. Very small, but very accurate machine. I’m going to use it to make the small items for the model cars, like the head lights, the mirrors, the wheels, etc. It’s capable of milling hard wood, plaster, plastic, aluminium, etc. It’s also capable of 3D digitizing…
    But I’m with the problem of the body. Especially by the size of it. I was considering many options, including a spectacular (for me) “enlarging machine” that I’ve invented.
    With that, I could start with a 1/24 or 1/18 scale model and then I could make an enlarged model in foam (6 to 8 times bigger than the original) by a mechanical device, with out any electric or electronic device (except for the spindle motor).
    This is a very time consuming machine, because it couldn’t work by itself.
    The result it’s a not very accurate model, especially because all movements are enlarged 6 to 8 times, including all the errors and the smallest details…
    But it’s a good starting point to make the models in 1/3 scale (about 1,5 mt length)
    But the main reason of this post is that, after I found this group, and a couple of related links (about home made CNC machines), my thoughts went to build a CNC machine that could make my models in foam, but very much accurate and with other scales also.
    My questions are, if anyone can take his time for it, and having in mind that I don’t know almost anything about electronic devices:
    Can I actually build a 4 or 5 axis CNC Machine?
    How much would the cost be?
    Are there any plans or kits to start from?
    Can anyone tell me how can I achieve that?
    Thanks in advance for the time.
    Best regards from Portugal,
    Ernesto Freitas
    Gold Member
    Jun 2003
    you might be interested in this:
    http://www.rainnea.com/cnc_5axisMill.htm there is a gantry too.
    Jon
    Gold Member chuckknigh's Avatar
    Apr 2003
    Default Re: 5-axis self build?
    This sounds like a very enjoyable project. Welcome, Ernesto, to the group!
    Let's take your questions, one at a time.
    Of course you can build a 4 or 5 axis CNC machine -- trust me, anyone can do it. How much of the project *you* do will help to determine your final cost.
    Let me make the following suggestion. It's often suggested that someone build a small, simple machine first, as a learning experience. You could build a large 3 axis machine, and add the additional rotational axes later, as you gain experience.
    The cost is going to be highly variable. Assuming this machine would be used only to cut foam, the loads on the parts would not be very great.
    You'll have to tell us what level of accuracy you want, but it should be very possible to make a medium to large sized machine, from commonly available parts, and to do so relatively inexpensively.
    If you want to upgrade your parts (for example, manufactured linear rails, rather than something homemade) it'll cost more.
    As for existing plans, there are quite a few sets of them, some of which are offered by people on this board. I'll let them respond to this question, specifically.
    If you give us some more details about your requirements (what does "very accurate 1/3 scale car models" actually mean, in terms of dimensional errors? +-1mm, or +-1um?) and some more details on the project, I'm sure we can come up with some specifics!
    -- Chuck Knight
    Member HuFlungDung's Avatar
    Mar 2003
    One of the big hurdles to overcome is the cost of the 5 axis cadcam software. If I were in your shoes, Ernesto, I would shop around and see if there is 5 axis software within your budget.
    Jul 2004
    Portugal
    Thanks for your reply.
    In fact +-1mm is more then acceptable.
    I can make (or have someone to make it for me) almost all the “mechanical” and structural parts. I only have to get the electronic stuff and learn how to build it up all together…
    Of course there is the software problem, but let’s forget that for this moment.
    Best regards from Portugal.
    Ernesto Freitas
    Jul 2004
    Portugal
    JFETTIG,
    Was that build by any plans? I'm just in love by the 5-Axis Gantry Router. It's a dream come true.
    Ernesto
  7. #7
    May 2003
    UK
    You don't need 5 axis, I bet you can do many things you wish with 4 axis or with fixtures, especially in foam.
    I made a 5th axis for my mill, had no time to really try it yet, it is also for foam. Check out my site and you will see I make model planes. I also made a digitizer to help copying models etc.
    Ernesto, he built it from scratch no plans, the 4th/5th axis are surplus satalite dish turners, the rest is standard router. He uses his own kit of macros in a 3D program I forget the name of. You can get the toolkit from him and join the yahoo group, there is also a free version of the 3D package called gmax, it is limited but you can import from other programs etc.
    Cheers,
    Graham
  8. #8
    Jul 2004
    Portugal
    Can you please tell me you site?
    Ernesto
  9. #9
  10. #10
    Registered Patrick2by4's Avatar
    Feb 2004
    In the rainea site, he incorporates two pancake type axises in order to make his birotational head on his z-axis. Where can these items be purchased? or if there is a kit to build it, where would you purchase it?
    I would imagine that if he machined it himself, he must have incorporated two stepper motors in the head.(one to control the A axis and one to control the B axis) They would have to be small and use small internal gearing in the pancake-like housing. From the picture, I can see a stepper motor on the head but only one from the angle shown.
    -Patrick
    _____________________________________________
    measure twice, cut once - a good rule for everything
  11. #11
  12. #12
    Gold Member
    Mar 2003
    Well, looks like they have discontinued the item. Try this.
    http://cgi.ebay.co.uk/ws/eBayISAPI....item=3826181817
  13. #13
    Feb 2004
    hey marv
    I tried both links but they seem to be nonworking. This 5 axis router is quite a idea though, I wonder if anyone built one yet?
    -Patrick
  14. #14
  15. #15
    Feb 2004
    gracias
    -Patrick
  16. #16
    Member Switcher's Avatar
    Apr 2005
    Patrick2by4
    Looks like 2 steppers (C & B) http://www.rainnea.com/tilt-swivel-head.jpg
    That is a cool setup!!
  17. #17
    Feb 2005
    Indonesia
    I can't find on that site about Tilt Swivel head, is there any place I can buy that stuff ?
    can't find on ebay also ... nobody would sell that...
    I would love to buy that...
    rud
  18. #18
    Registered rab's Avatar
    Jun 2003
    Scotland
    I made my 5-axis head from two of the surplus Sat drives,
    I machined off the flanges and bolted them together in the most compact configuration that I could find.
    I replaced the dc motor and its gearbox with a stepper.
    It's actually up on ebay just now as I'm upgrading the machine to harmonic drive units (a lot more expensive) if you want to buy one ready-made.
    - item no. 7509162058 if that link won't work
    I wrote a plugin for 3DS MAX / GMAX that generates the 5-axis G-Code which currently gives you a free basic 5-axis CAM package.
    Regards,
    Rab
    Rainnea CNC
  19. #19
    Feb 2005
    Indonesia
    thank you for pointing out, how come i can;t find it when i search it in ebay.
    anyway ... they are in UK, they won;t ship to Indonesia
    how much you bought it anyway ?
    regards
    ruddy
  20. #20
    May 2005
    Where did you find the sat drives?
5-axis self build?
5-axis self build?
