Hey Dustin,
Knowing you like I do I am tempted to take this off forum but I have looked so hard to find some 5 axis info lets leave it here and maybe everyone can benefit.
First I want you to know I am not nuts. I want to build two 5 axis machines! I want to build a really small one but I also want to build a fairly large envelope machine too. Like the starter of this thread I want to carve car parts or full bucks from foam or mdf. Nothing any harder than that. Due to the size of the parts I need this thing to move right now! With that in mind it needs to be light weight and stiff. So how do I do it? Ok enough of the emoticons!
What I am after is a machine that can carry a spindle that will handle as large a bit as possible and still be nimble. I plan to use good linear ways with belt drive for the x,y and z. I am curious if a stepper will give enough holding torque to keep a 4th and 5th axis in place while machining mdf at 3-500 ipm?
I will machine it faster than that if I can come up with all the right compontents.
I would like to build the b/c rotary and yoke out of aluminum honeycomb and carbon fiber for stiffness and the ligthness. Do you think this will work? If so co you have any pics of a yoke head that I could get some specs from?
Mike
ps on the small machine, I am certain the composite I described will work. I just need to design that little yoke thingy!
