5-axis self build? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 57
Thread: 5-axis self build?
  1. #21
  2. #22
    May 2005
    Those are the ones I have on the way. I guess I just did't think they were that small after the large diameter is cut.
  3. #23
    Feb 2005
    Indonesia
    is it correct it has .5degree backlash ?
  4. #24
    Registered rab's Avatar
    Jun 2003
    Scotland
    The backlash seems to vary between units,
    The ones I got had quite a bit of backlash in the reduction gearboxes integrated with the motor.
    Rab
    Rainnea CNC
  5. #25
    Feb 2005
    Indonesia
    how is your harmonic gear ? have you got it ? WIP ?
    rud
  6. #26
    Jun 2003
    Scotland
    the units are here, I just need to machine up motor adaptor and mounting plates
    Rab
  7. #27
    May 2005
    What do they look like? Any pics?
  8. #28
    Feb 2005
    Indonesia
    yeah any pictures ?
    i wonder how big it is ?
    how much you bought it and where ? ebay ?
    I bought mine quite expensice US$ 200 1:50 ratio.
    rud
  9. #29
    May 2005
    what kind is yours for $200?Any pics of that one?
  10. #30
    Feb 2005
    Indonesia
    here it is
    Attached Thumbnails Attached Thumbnails 5-axis self build?-image_00041-jpg   5-axis self build?-image_00042-jpg   5-axis self build?-image_00043-jpg
  11. #31
    May 2005
    Who makes that one? Do they have a smaller one?
  12. #32
    Feb 2005
    Indonesia
    well the problem is I do not know what brand it is.
    I saw smaller than this but longer.
    I need short for my 4-5 "spindle" axis.
    it's japan made, the bearing brand says NSN or something, defenetly not NSK.
    if anyone knows who made it let me know, I just want to disassable it but I need the drawing to do that, don't want to damage the bearing.
    rud
  13. #33
    May 2005
    Where did you see them? What site?
  14. #34
    Feb 2005
    Indonesia
    i was in singapore, it's where I got mine from.
    I don';t think he sell it for public.
    rud
  15. #35
    Jun 2003
    Scotland
    http://www.harmonicdrive.de/en/2_3_1.htm
    I paid £400 for a pair of new, old stock, size 20, 50:1 ratio
    Rab
  16. #36
    May 2005
    Any progress on your new head?
  17. #37
    Feb 2005
    Indonesia
    I'm busy making the body frame , the head going to be the last.
    check this out
    http://www.5-axis.com/
    does anyone has any clue what''s inside ?
    any idea how to make it ?
    any drawing ?
    does they use harmonic gear ? I don't think so.
    they said it's servo driven.
    rud
  18. #38
    Member Switcher's Avatar
    Apr 2005
    Calico, Cool Link! Did you notice in the videos that they didn't do any actual cutting? (Just followed the Cutting path/Contour, of a part already cut) I want to see chips Fly!
  19. #39
    Jul 2005
    Ernesto,
    Most of the clay/foam mills I have seen in design studios are 3-axis horizontal arm type machines. GM has machines made by Tarus... maybe a google search can yield some pictures. Basically, there is a track in the floor that runs beside the car (front to back). On this track is a tower (Z axis) and from that tower a horizontal arm that runs cross-car (Y axis).
    The spindle is a seperate router looking thing. It is set to different angles - so the software creates different files depending on the angle. Only one side of the car is done at a time. They have the luxury of having a machine on each side, but you may have to rotate the model or have a duplicate floor track.
    Just my two cents.
    Henry
  20. #40
    Gold Member
    Jun 2003
    http://www.tarus.com/styling
    This site is well worth the visit. While I am here, is there anyone that has any experience with 5 axis that could spend a little time with us here. I have several questions and need some input from someone who's been there.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
5-axis self build?
5-axis self build?
