1" is not 25mm, and bearings for either size would not be interchangeable.
If the original bearings were plastic, than there's a good chance that ball bearings may wear grooves into the shafts.
Igus has a large range of plastic bearings that may work for you.
https://www.igus.com/iglidur/plain-bearing
