How many sheets do you need to cut per day?
What size are the holes, and how many per sheet?
What size are the parts?
If all that you're cutting is 3/8" plywood, you can probably get away with spending a lot less than $100K.
Hi folks,
Big newbie here so bear with me. I am a student at Virginia Tech studying Industrial Engineering and my senior design project is to implement a CNC router for a local company. I have done a fair amount of research but I think it would be better to post on here to get directly related feedback on the issue...
I know a lot of choosing a router is based off the material being cut. I do know that we will be cutting primarily Russian Birch (3/8" thick) (5x5 sheets). There won't be any complex cuts, essentially just cutting rectangles and drilling holes.
Like anyone else we are looking to maximize throughput while minimizing waste. I think we are probably looking into the $70-100k+ range. I know we need to take into consideration IPT, SFM, IPR, RPM, etc. But I really don't know how to determine what we need.
Any help from y'all would be great!
Thanks in advance!
UCCNC 2017 Screenset
working area 1200*1200mm or 1300*2500mm,
3axis ball screw or XY helical rack
air cooling or water cooling spindle
control system,handhold like NK105 or Mach3
Aluminum T slot table
If you buy from China,shipping ,import cost and so on.
