- Need Help!- Need some guidance switching controller for AXYZ 5012 Table
Hey,
I recently picked up an AXYZ 5012 table in "kinda working" shape. I bought it second hand from a shop using it to cut corian. When I bought it the machine could jog in the x/y directions but couldn't perform any functions. It was believed to be the controller (which they had a spare they had not installed yet included) so I took a gamble. The machine was very poorly maintained as they went through linear bearings almost ever 14mo. So I disassembled the whole machine down and cleaned it to each individual bearing. It was an exhausting process but the bearings were CAKED with debris. I finally got the machine to a state where I can begin troubleshooting and I'm at a deciding factor on either purchasing the AXYZ support plan ($500) and hoping they can help me get the machine running or replace the controller with something more open source/user friendly or spending a couple $1000 on a plug and play retrofit kit... Some insight would be greatly appreciated.
More details
AXYZ 5012
10hp hsd spindle, 5hp ELTE spindle, air drill
Becker 10hp vac pump
Upgraded controller to A2MC
pop up pins
pressure foot
emerson commander se size 3 inverters
Currently I can not get the Z axis to move (either carriage)
The Y axis seems to think the center of the table is home
one of the inverter needs a fan replaced (not a big deal)
I have not seen either spindle run but is assumed they work (seller seemed pretty honest and straightforward)
All the motors and drivers seem fine (z axis is unknown however)
This machine was purchased for my business (mostly cutting aluminum) and although I'd like to be budget conscious, I don't want to spend weeks/months getting this thing running as I'd really like this thing to start making me some money. I'm pretty good with my hands but lack the programming technical side of things. I have some general knowledge on cnc's so I think I will be okay doing the retrofit myself as this is my 3rd cnc. (2448 cncrouterparts router, and arclight dynamics 5x10 plasma) Some insight would be greatly appreciated.
Is swapping out the controller as simple as getting a new controller and plugging in all the input/outputs? How does the configuring/programming side of things work? If anyone can point me in the right direction for this process that would be greatly appreciated.
-Benny
Re: Need some guidance switching controller for AXYZ 5012 Table
There was another gentleman, kennected, I believe, who also bought an AXYZ machine and was looking at a retrofit of some kind.
So does this thing currently have stepper motors running it?
You're looking at replacing the controller but keeping the same motors?
For a 3 axis machine running steppers, it's pretty straight forward to swap out the controller (drivers, board) but in your case there are a few things that go beyond the normal diy setup. That would be the dual Z axis and the Automatic tool changer.
You mention the Z axis won't move. Is there a pneumatic counterbalance in there somewhere? Is it charged up to the correct pressure? What kind of control software is this setup using?
Sorry I can't be more help. Perhaps some pics of the Z setup and the current controller will help in getting some feedback.
- You may not post replies
- You may not edit your posts
Forum Rules
