Looking for PLC for morbidelli 510
Results 1 to 16 of 16
Thread: Looking for PLC for morbidelli 510
    Jskaft's Avatar
    May 2017
    Roskilde
    Default Looking for PLC for morbidelli 510
    Hi
    We have an old morbidelli 510 that have been shut off for about half a year. As a result the battery died and thus it lost its PLC. I've been searching everywhere for the backup disk but it seems lost. So as the title states i'm looking for the PLC for a morbidelli 510.
    Any help or tips is much appreciated.
    Regards
    May 2017
    Lithuania
    Default Re: Looking for PLC for morbidelli 510
    If I understand correctly you need parameters?
    I have them for Morbidelli Author - 400. I think it should work for you
    If you want them tell me where to sent it for you.
    Sep 2017
    New Zealand
    Quote Originally Posted by Jskaft View Post
    Hi We have an old morbidelli 510 that have been shut off for about half a year. As a result the battery died and thus it lost its PLC. I've been searching everywhere for the backup disk but it seems lost. So as the title states i'm looking for the PLC for a morbidelli 510. Any help or tips is much appreciated. Regards
    Hello From New Zealand I am helping out a local Maori carving centre, Whakaraupo Carving Centre, here in New Zealand and they have a Morbidelli Author 510 that they bought on a bit of a whim and have yet to use because they don't know how to use it. I'm looking to find the manual and any information on how to use this machine. I believe Morbidelli is now all under SCM and I'm in touch with them but, so far, they have not found a manual for the Author 510 and have requested the serial number. We're looking for that now and hope to get back to them soon. Any advice or information on how to proceed would be greatly appreciated. Cheers!
    May 2017
    Lithuania
    I have uploaded my Morbidelli Author 400 parammeters files to WeTransfer. Here is the link:
    https://we.tl/Jqt3H1Gcp1
    You will also need a DEF file for the tools.
    May 2017
    Lithuania
    Hi
    Regards
    Sep 2017
    New Zealand
    Sorry to bother you but can you provide another link to the parameter files? We have a Morbidelli 500 here in New Zealand and need this file also.
    Thanks!!
  7. #7
    Sep 2017
    New Zealand
  8. #8
    Member gccp's Avatar
    Apr 2019
    hi,
    i have a morbidelli 510 and i need restore PLC because battery is dead.
    can you help me?
    mail gccp05@gmail.com
  9. #9
    Member Karbid's Avatar
    Sep 2020
    Quote Originally Posted by Dovydas View Post
    Dear sir. I need thees parameter Because my machine lost all parameters during corona crisis. If You have them please help.
  10. #10
    Member Kassas's Avatar
    Oct 2020
    I need author 510 plc and def
  11. #11
    Also Looking for Morbidelli Author 510 PLC and tool DEF files. Possibly instructions on how to load them as well. Anyone able to share their's?
  12. #12
    bruno_cunha's Avatar
    Jan 2021
    Quote Originally Posted by Karbid View Post
    Hello, do you have it?
  13. #13
    Member ztPod's Avatar
    Dec 2021
    Hi
    Regards
    Hello. As I understand it, you are looking for floppy disks with programs for launching the pltz and automatic pantograph settings. Just a couple of days ago, we faced a similar problem, since the battery went to zero and all the settings went off, but we were beaten by images of these floppy disks. If you need them, I can upload them to the file hosting service and drop the link. Just point out which file hosting service is to throw it, since I'm from Ukraine.
  14. #14
    Dec 2021
    yep
  15. #15
    Dec 2021
    If you still need these files, I can send them to you through a file hosting service. The procedure for installing DEF files is carried out by copying them from a floppy disk to a directory on the internal memory of the PLC computer, you first need to create a directory in the main root of the system with the name DEF, then copy the data in the form of an ATR file to this directory. I can drop these files, but preliminary preparation of a floppy disk is necessary (our system works on a floppy disk). It is impossible to simply upload a file to a floppy disk through a regular computer, since the PLC works with the so-called industrial floppy disk format. You just need to format the floppy disk first directly to Author 510 (it will become 1 MB in size), then you will need to insert it into a regular computer with a floppy disk and copy all the files there (which, if you need to, I will upload to the file hosting service). After that, you can calmly do the initialization procedure for DEF files from the floppy to the PLC.
    - - - Updated - - -
    Quote Originally Posted by akasealy View Post
  16. #16
    Member vindelans's Avatar
    Jan 2022
    Hi!
    I am looking for a PLC for our Morbidelli 400, for the same reason as many others. (batteryloss causing the PLC to disappear). Any of you happen to have it?
    Regards
    William
