- Biesse XNC programming help
Hi guys
I am rather new in the domain of CNC routers and as a hobby project I am trying to learn how to run with a Biesse Rover running with an XNC controller. (Yes it is some old machinery)
We already had some success meaning that we have a CAM solution for 2d cutting working ok. However, now we have started to run with an aggregate which is rather challenging. On that matter I would like to hear if someone has some training material on how to run with the aggregate that they can share? I am mostly struggling on understanding the relation between the tool setup and how the tool is positioned in the g-codes. What I don't understand properly is what the controller does when rotating on the C axis, is the X Y offset maintained in respect to the configured or do I have have calculate to tool position manually?
If anyone have some training material describing this, og example programs it would be very welcome.
BR
Kasper Revsbech
- You may not post replies
- You may not edit your posts
Forum Rules
