- Problem- RZNC-0501HBBC vs. HKNC-0501HDDC
For some kind of reason (probably since I decided to purchase on) I have a larger cnc 3D router. It came with a handheld controller: RZNC-0501HBBC. However, the controller did for some kind of reason not work, as it refused to save the parameters, so I sent it back to the supplier, but I had to realize that it "was lost in transfer". Then I got another controller; a HKNC-0501HDDC. That one worked, as it at least stored the parameters, but beyond that the CNC router is still standing still, as it has done for more than two years.
Q.: Are there any differences between a DSP RZNC-0501HBBC and a HKNC-0501HDDC, - except for the model names, like different software, setup, etc?
- You may not post replies
- You may not edit your posts
Forum Rules
