- Biesse Rover 322 - SNI XNC COMPACT import files from CAM ?
Hi there,
we have Biesse Rover 322, 1998 - SNI XNC COMPACT from about 10 years, and use it only simple details.
We need to make more difficult 2D forms and with the basis software this will be mostly impossible. I've read a lot in the net, but only in old discussions.
There is no network card installed in the controller. There is place for USB at the main board, but with no USB connectors.
Is there any solution now to import files directly from my PC, and can I use floppy to USB converter ?
Thank you in advance.
Re: Biesse Rover 322 - SNI XNC COMPACT import files from CAM ?
dxf files are how we do nesting sometimes
- You may not post replies
- You may not edit your posts
Forum Rules
