We uploaded a video of the E3 CNC engraver making its first cuts.
We are pretty excited about the new engraver we are bringing to market. It should be out by the middle of next month (Oct 2016)
CNC Engraver with the DeWalt DW660 - Album on Imgur
The E3 CNC Engraver has the following features:
A rigid laser cut frame
SG20U supported rail system
GT2 bet drive on X and Y axis. 5/16-18 dual brass nut on the Z axis
Home switches on all axes
MDF Spoil-board with 1/4-20 threaded inserts
DeWalt DW660 router
The assembled foot print
Length: 24.8" (630 mm)
Width: 25.2" (640 mm)
Height: 18.9" (480 mm)
Assembled Weight: 25 lbs
Cutting Area
X: 17.7" (450 mm)
Y: 15.3" (380 mm)
Z: 3.3" (85 mm)
Gantry clearance is 3.1” (80 mm)
The plan is to keep the cost under $600.
- News BobsCNC.com is working on a small CNC router - Second prototype has is built
- New Product- BobsCNC.com is working on a small CNC router - First prototype has is built
- News RP9 Deluxe 3D Printer Kit by BobsCNC has free shipping through Dec 1st
- RP9 Basic 3D Printer Kit by BobsCNC - 5 Ply Birch Plywood with Motion Hardware
- New Product- RP9 Basic 3D Printer Kit by BobsCNC
The assembly manual can be downloaded at: E3 Engraver - BobsCNC is a small family business that sells simple and cost effective CNC DIY Router and 3D Printer kits that are designed and manufactured in the USA.
We are ramping up for a production run. We are still planning to be selling by the end of this month (Oct 2016)
I just purchased an E3 CNC. I am eager to assemble and try the machine. I think it is an appropriate price tool to familiarize myself with the process and to learn what is required to build a larger 1.5 x 3 meter table in the future. I only just found this in Amazon search in a last ditch effort to avoid spending 1600 on an Xcarve I was not sure I would be happy with in the long term. Part of what convinced me was that I have a printer I built 3 years ago with a laser cut frame and mechanical structures. Over the three years I have replaced many of the mechanical parts with parts that I have made in other ways. In two weeks, I will finally remove the last of the laser cut plywood parts from that printer to form a full metal frame. It has served me more adequately in all that time. There have been plenty of review about systems that are too flexible and costly for limited functionality at any price from 1500 to 5000. Based on my previous experience with the frame stability technique used in the E3, I went with this machine over the competitor.
