Any cadcam system will work but you must convert the txt file to binary using a morbidelli utility called xiso. PM me if you want a copy. There is no license so nothing illegal in sharing it
Hi all,
Quite a few years ago my Dad bought a Morbidelli Author 213 but not any of the CAD/CAM software to go with it (Aspan?). When they sold him the machine, they made it sound like Aspan was tied to the machine so any other software wouldn't generate the "correct" g-code. Now that I've looked into it, I doubt that's really the case. Unfortunately I'm in another state so I can't just duck over to the factory to play with the machine (I will be going down at Christmas though). In the meantime, I'm getting my Dad to email me a few files contained on the floppy disc that's in his machine. I'm hoping I'll open up the files from the machine and they're just plain text g-code but if they're not then I'm in a bit of a tight spot.
I did some googling and saw a bloke selling an identical machine, he put in the description "Works with all the major CAD/CAM software". That's encouraging but I'll have to see it before I believe it. I also did some searching on this forum and there was talk about a PGM file format which was essentially some for of g-code and a simple convert needed to be written to convert normal CAM g-code output to a PGM structure.
I'll find out more about it once I crack open the files but in the meant time, does anyone know much about these machines or their g-code format?
- Need Help!- Morbidelli Author 502
- Need Help!- Morbidelli Author 503
- Morbidelli Author 344
- Need Help!- Morbidelli Author 430
- Need Help!- morbidelli author 504
I know the subject is from long time ago, but do you think you could provide a copy of the winxiso.exe file ?
I found a link on internet, but when I try to use it with this file:
H DX828.00 DY357.00 DZ20.00 -A R5 *MM /OUT1
F1
B X85.50 Y257.30 Z29.00 V1 T18
B Y332.30 V1 T18
B X742.70 Y332.00 V1 T18
B Y257.00 V1 T18
B X1300.00 Y25.50 Z1.00 V2 T18
I have the following error
Compiled lines:7 Errors:52
and it doen't produce the pgm file
Could you send a copy of the utility or display a download link ?
Sorry to wake this converstaion but i have a huge problem! I have recently bought morbidelli author 213 and I only have a Italian language manual, for two months now i cant use the machine it is just standing there! I dont know hot to start it or know to write one line to have her do anything!!! It is in perfect shape and it is just sad standing there! If anyone has some instruction or english manual i will be so thankfull! I would appreciate if u stil have that xiso software!
THANK YOU ALL IN ADWANCE!
