Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Colchester Tornado lathes
Colchester Tornado lathes Discuss Colchester Tornado lathes here
Old 01-28-2009, 09:35 AM
delta_david is on a distinguished road
Losing parameters
About 2 weeks ago i lost all the parameters for my colchester T110 lathe with 21i control,
After speaking to colchester i replaced the CNC battery behind the screen and re entered all of the parameters manually, encountering a few problems along the way!
When i switched the machine on this morning all of the parameters have gone again, i have checked the voltage across the battery and it is reading a steady 3v as it should,
What else will cause me to lose parameters? and what can i do about it?
Dave
Old 05-17-2010, 10:34 PM
MarineMachinist is on a distinguished road
Not sure about your model, I have a T8MS, and had to replace the Fanuc Servo batteries. Does it give you and codes etc... i.e. 300 or 306?
Tags
21i, colchester tornado, fanuc, parameters
T32 Losing position apylus444 Mazak, Mitsubishi, Mazatrol 2 07-26-2008 11:57 PM
Help with CNC losing steps Scramjet DIY-CNC Router Table Machines 6 01-29-2008 07:24 PM
Z losing Step going down bullseye Syil Products 7 11-01-2007 06:48 PM
losing position in X martsto Milltronics 3 03-15-2007 09:55 PM
Losing steps - WHAT IS UP?!? Sporqster DIY-CNC Router Table Machines 10 04-27-2006 10:50 AM
