Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Colchester Tornado lathes
Colchester Tornado lathes Discuss Colchester Tornado lathes here
Old 11-14-2008, 02:21 PM
newcol is on a distinguished road
colchester 100 with fanuc control
I an trying to sort out a colchester tornado 100 lathe with fanuc control.I am able to enter a programme in to the machine and to run it. When the machine is switched of with the programme protect on the machine corrupts the programme when switched on again. It comes up on the screen with a lot of "O". I have changed the batteries for the memory to no avail. The odd thing is that there is a programme in the machine which remains in memory and i am able to run everytime. This seem like a problem with the fanuc control. Anyone have any advice to resolve this?
The machine has a RS232 port and i would like to try communicating with the machine from a PC. Does anyone have a software programme which will enable me to do this? I could the write the G codes on the PC and save them there for future use.
Old 11-17-2008, 01:39 PM
Afzal is on a distinguished road
Hi newcol,
u try to machine Switch off with out pressing Emergensy Switch.
and comunicate it with the edgeCAM.
when u instal it, it have a *.exe to check the settings of machine comunication.
"netscope.exe"
Old 01-03-2009, 10:48 AM
Jeroen aalders is on a distinguished road
Hi
I ussed to work with a takisawa lathe that had a fanuc controle. some times did run in to some simulare kind of problem. not storing a programm is often caused when there is not enough memory.
so i check the control for the amount of free memory. try to keep as less programms in the control as possible. but use a pc or laptop for storing the programms and send them to the control if you need them.
when you want to switch the machine off you need to press the emergency switch first.
bye the way know i own a colchester triumph with a allen bradly osai control. that doesn't store programms propperly when the memory is full.
Old 01-03-2009, 12:18 PM
fanuc control
Thanks for response. the machine only has the one programme in memory so it seems unlikely to be a capacity problem. What software is needed to connect a PC to store and download programmes?
Old 01-03-2009, 02:30 PM
NC Cams is on a distinguished road
waht model Fanuc???
Type of BTR will greatly depend on model type.
same goes for prior problem troubleshoot. Resluts and solutions differ according to model.
More info needed.
Old 01-03-2009, 03:32 PM
Al_The_Man's Avatar
Almost any configurable Modem program will work from Qmodem, Windows Terminal etc, you need to know however, the protocol the Fanuc is set to.
Here is an example of the 0, most Fanucs use the same cable configuration, I always use the 3 wire version.
Any word processor that does not embed codes can be used as an editor, WordPad in txt mode for e.g.
Old 01-04-2009, 10:04 AM
i still got some old dos version of bobcad wich works fine for most of the machine and i'm sure it works with fanuc osai and heidenhain controles.
just send me a msg and i can send the programm to you
Old 01-04-2009, 11:20 AM
Glanshed@ukgateway.net Thanks
Fanuc OT Control/Colchester 2000L Lathe okhan Fanuc 11 12-15-2010 12:18 PM
Colchester Tornado Fanuc 21i-t Stebedeff Fanuc 2 11-07-2010 08:43 PM
Colchester Tornado 200 Fanuc OT Control - Turret indexing problem JohnWD Fanuc 10 12-29-2009 10:10 AM
ID Colchester Lathe dwl General Metal Working Machines 2 05-24-2008 03:23 PM
Problem- colchester cnc 200l briggs Machine Problems, Solutions , Wireless DNC, serial port 0 04-07-2008 02:29 PM
