Results 1 to 7 of 7
Thread: Fanuc programming
    Feb 2008
    gwent
    Fanuc programming
    Can someone tell me how you change between nunbers and letters on the Fanuc TO keypad. Cannot search programmes which all start with letter O which is on key with 7.Thanks.
    Jun 2005
    us
    Press the shift key then the letter.
    Tim
    Feb 2008
    gwent
    fanuc to
    Thanks which is shift key?
    Sep 2005
    Is there soft keys on the crt? if there is, look for forward search
    Feb 2008
    gwent
    Fanuc Programming
    Hi There. Thanks for response. There are soft keys but have not seen forward search. Will look again.
    Registered gmilosevic's Avatar
    Jan 2007
    U.S.A.
    Try typing in the program number then the down arrow key, you may or may not need to be in edit mode.
    Feb 2008
    gwent
    Hi have made some progress since last post. However I can enter a program into the Fanuc to controller on the Colchester using a new programme number and in edit mode with programme protect off only to find when I put programme protect on and switch off machine the programme is not saved or is partly there but corrupt. A row of noughts appears aftera line number. What am i doing wrong?
    1. Programming FANUC 21i-TB
      By neroseu in forum Fanuc
      Last Post: 07-25-2011, 08:10 AM
    2. Programming PLC on Fanuc 0M
      By MetLHead in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 06-27-2011, 07:47 PM
    3. Fanuc 18i Programming
      By jorgehrr in forum G-Code Programing
      Last Post: 09-21-2007, 01:36 PM
    4. Fanuc 6T Programming
      By Garry Neal in forum Fanuc
      Last Post: 02-16-2007, 03:11 AM
    5. Blueprint Programming fanuc 18T
      By adamant in forum G-Code Programing
      Last Post: 09-12-2005, 01:22 AM
