| Colchester Tornado lathes Discuss Colchester Tornado lathes here |
hi all i have an alarm no 1038 (head stock lubrication loss) the machine is ALPHA 1400 XS 600 Group The controller: COLCHESTER –HARRISON GE Fanuc ALPHA X Series i checked the oil level in the tank for slides lub and it's full also the oil level in the gear box is full nothing helps in the manual ![]() ![]() thanx in advance for any help |
| chances are that you moved the machine recently and you need to change the two phases in order to correct the phase . I f you open the back you will see two hoses going to the spindle the big hose is the return and the small hose goes through a filter and supplies oil to the spindle bearings |
| Need Help!- Lagun FTV-2 Gear Head lubrication point location | ab4td | Knee Vertical Mills | 2 | 12-14-2010 10:33 AM |
| J Head Lubrication | pearldiver | Bridgeport and Hardinge Mills | 0 | 07-11-2009 01:10 AM |
| Need Help!- Head Stock alighment | leeharrysouth | Shopmaster/Shoptask | 11 | 11-11-2008 01:48 PM |
| Mazak QT-20 HP Alarm Head Lubrication | Carnedude | Mazak, Mitsubishi, Mazatrol | 3 | 07-22-2008 03:06 PM |
| head stock and tail stock chucks | mocnc | DIY-CNC Router Table Machines | 3 | 10-19-2004 09:16 PM |
