Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Colchester Tornado lathes
Colchester Tornado lathes Discuss Colchester Tornado lathes here
Old 05-28-2011, 06:14 PM
hmc710 is on a distinguished road
Spindle alignment
Have a Tornado 200 and did a spindle alignment test cut on a 3" dia piece today. Got 2.953 on the far side and 2.950 on the chuck side. Cut was 5" long and got .003" run out. I don't have a manual that describes the adjutment procedure but I did pull the front cover off and found 2 sets of bolts on the motor end, the other side of the spindle block has the interior cover attatched to it. Is this a jacking bolt adjustment or a shim adjustment?
Thanks,
H
Old 05-29-2011, 01:59 PM
OK, got to this point
There are two allen head set screws on the lower left front of the spindle base as seen in the top picture. In the manual on the base frame is shows an "adjusting block" in this area on the frame. There is a gap between the spindle casting and frame casting under these screws. I took the left screw out and it has a machined end on it. There are two allen head bolts on each corner of the spindle casting and the spindle is belt driven.
It's taken a while to get to this point and apparently I'm going to have to put the chuck back on to make another test cut after any adjustments. Unfortunatley, the covers will not go back on the machine with the chuck in place, and you can't get to the base bolts with out the cover removed.
1. Should the drive motor be loosened up to make any base adjustments?
2. Shifting the spindle base on its mounting pad does not make a perpendicular move with the X axis. How to you take out a taper unless you have a jacking bolt or shim the spindle?
Thanks,
H
Old 05-31-2011, 06:04 AM
600Service's Avatar
600Service is on a distinguished road
Hi HMC710
1. Yes, the drive belt does need to be loosened off before adjusting the head.
2. Cut and test to get the desired parallel tolerance for the amount of tool pressure you will be applying when taking your usual finishing cut. The bigger the cut the more push off. Use the 2 allen screws bottom left of the headstock to pivot the head and remove any unwanted taper from the finished turning. One of the allen screws pushes and the other pulls the headstock to move it around the pivot. A tip is to leave a little nip on the bolts top right where the pivot pin resides, slacken off all the other bolts.
Old 05-31-2011, 08:23 AM
Pivot Pin
Thanks 600,
Pivot pin is located upper right then?
Just got the chuck back on and getting ready to dial it in so I can make a cut. (then take it all back off so I can put the panels back on.......)
Thanks,
H
Old 05-31-2011, 09:08 AM
600Service's Avatar
Originally Posted by hmc710 View Post
Thanks 600,
Thanks,
H
That is correct. As you look at it from the front of the machine.
Old 06-01-2011, 10:55 PM
cncatj is on a distinguished road
Hi H !
do you have this job done ?
Old 06-02-2011, 05:35 AM
Hey cncatj! How are things down South? Almost done, lined it all up with a few tenths of taper in 5". Pulled the chuck back off cleaned all the gunk off guards up and put them back on the other night. Now its just truing up the chuck again. I played around with different distances that the hydraulic jaw actuator was screwed on, I lost some travel the first time I put it back on. I was hoping to get it all done yesterday but spent all day doing eng drawings and cutting parts on the table. Once I get the chuck dialed in I'll clean up the guards with some 409 and check all my offsets. Then its on to tail stock alignment......
A big thanks to all the help out there in cnczone land!
H
Old 06-03-2011, 04:21 PM
Things are quite good Here H !
It's good to hear that your machine is almost finished ,
I'm now taking a turret all apart !!
Puting all new Orings & seals
Old 06-03-2011, 04:56 PM
Good luck with that, I'm hoping I won't have to do that anytime soon. Got tailstock aligned and cut true for a few pcs then got some taper back. Changed out my cutting insert and will try another cut. Is there an adjustment on the hydraulic pressure on the turret? Mine seems to slam hard into position, I'm just not that much in a hurry. Also can the coolant flow be adjusted down?
Thanks,
H
Old 06-06-2011, 11:38 PM
Sorry for the delay H ,
About your turret issues , The slam in my opinion can be caused by several reasons:
1-The shock absorbers , Does the turret slams in both directions ?
2- Not enough lubricant inside the turret ,Duplomatic suggest a special type of lubricant
also about the coolant flow , I'm not sure if the flow can be adjusted down ,
by simply rotate the coolnt disc , H , P.M your email adress
  #11   Ban this user!
Old 06-07-2011, 06:23 AM
I've only seen the turret go one direction. Shock absorbers? Will check into the lube. My turret has drilled balls where the coolant comes out. PIA to adjust or control. PM sent.
H
Spindle alignment fastpcuser Momus Design CNC plans 4 05-27-2011 09:15 AM
Newbie- Need Help with Spindle alignment! Darian S DIY-CNC Router Table Machines 19 10-25-2010 09:04 PM
Spindle Alignment forrest39 Benchtop Machines 9 08-03-2010 05:36 PM
Toolchanger/Spindle Alignment lovell110 Haas Mills 3 06-14-2007 06:26 PM
Spindle is out of Alignment Crashmaster General Metal Working Machines 2 04-05-2007 10:32 AM
