| Colchester Tornado lathes Discuss Colchester Tornado lathes here |
| Transfer program from PC to OT control On control edit - program - input you will see LSK on control send prog from PC Transfer program from OT control to PC get PC ready On control edit - program - progam number (example O0001) - output start hope this helps regards Les Robbins EditComm - CNC communication software - Les Robbins CNC Services |
| Hi Les, I can send from OT to PC, no problem, just like you described. I've tried receiving programs from PC and I do get the LSK on the control but I get the 086 error. I don't know if I have tried it when in Edit - Program tho. That would put the current program on the screen correct? And the Input would over write the current program? I have tried it in Edit - Program - Program. Let me give it a try, Thanks, H |
| 086 error means the DR signal is turned off. Check your external RS232 cable pinout (look on my website in FAQ - url below) There should not be any connection to pins 6, 8 and 20 other than links at the control end (25 pin D type). I seem to recall a problem like this year ago because the PC was pulling down the DR signal when sending to the machine The other possiblity would be a faulty serial port on the control Hope this helps regards Les Robbins EditComm - CNC communication software - Les Robbins CNC Services |
| Thanks Les, I checked your cable on the FAQ and my cable does not have pin 8 jumped with pins 6 and 20. I also have my pins 2 & 3 crossed. I tried uploading again using Edit - Program - Program - Input and I do not get the 086 alarm, the LSK blinks and the PC says Sending, but no bytes ever transfer, it just sits there. I'm going to make up a cable and see what happens. I don't know why I can down load tho? Thanks, H Got it, made up a new cable and works fine. Thanks for all the help! Last edited by hmc710; 04-29-2011 at 02:29 PM. |
| Outputting Common variable values into a program (with automated program number) | yaji63 | Fanuc | 0 | 12-27-2010 02:55 AM |
| Newbie- My CNC doesn't read G02 X Y I J | Bazz | G-Code Programing | 6 | 10-06-2008 09:40 PM |
| 10T-F READ READ READ READ READ READ | dcoupar | Fanuc | 3 | 03-27-2008 05:39 PM |
| Gcodein - lisp program to read cnc files into autocad | wjbzone | Autodesk Software (Autocad, Inventor etc) | 32 | 05-10-2006 08:08 AM |
| Must Read for All | CBNDude | Product Announcements & Manufacturer News | 16 | 07-21-2005 09:14 PM |
