Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Colchester Tornado lathes
Colchester Tornado lathes Discuss Colchester Tornado lathes here
Old 03-08-2011, 02:24 PM
dbarath is on a distinguished road
Duplomatic 300 turret unclamped
CAN YOU HELP. Clausing Colchester Tornado/Storm 300 (1997) When start up, (1021) alarm shows turret unclamped. When indexing energizing cylinder does not travel out far enough to lock in. we tried to adjust proximity switch with no luck, we also tried with new proximity switch. solenoid button don't pup out unless we rotate turret head. We Need help
Old 03-11-2011, 02:34 AM
600Service's Avatar
600Service is on a distinguished road
Can you tell me the serial number of the lathe please?
Old 03-11-2011, 01:16 PM
Duplomatic Turret Unclamped
Hello, The Serial Number is:C30346 (1997 Storm300) Thank you, Daniel
Old 03-14-2011, 04:19 AM
kama is on a distinguished road
I had a simular problem AL1018 i think it was...
Look in my post : http://www.cnczone.com/forums/colche...18_turret.html
Old 03-14-2011, 10:21 AM
600Service's Avatar
I tend to agree with kama. Try the following:
1. Remove the round Duplomatic cover on top of the Turret.
2. Remove the cover at the rear of the Turret.
3. Using an allen key in the end of the Turret motor, rotate the motor in any direction.
4. Hold in the solenoid at the top of the Turret.
5. Rotate the Turret motor until the solenoid goes all the way in.
6. When it goes in all the way then start to rotate the Turret motor in the opposite direction.
7. When you make this initial movement of the Turret motor then release the solenoid. The solenoid should now release.
8. Keep rotating the Turret motor in the same direction, this will feel as though there is a restriction. Keep rotating until this movement goes easy (At this point you are going up a cam, when it goes easy you have reached the top of the cam.).
9. At this point rotate the motor just short of a full turn. This should now be locked in position.
10. Check diagnostic 0 bit 7 and ensure this is set to ‘1’.
Old 03-23-2011, 05:21 PM
Storm 300.. I have tried all the steps that you mentioned and the turret just does not locks in and the Diagnostic 0 bit at 7 is not shows '1'. Ihave try to set the proximity switch to energize and dienergize but it is not working the lock is not holding in.
Old 05-07-2011, 04:53 PM
NICK1945 is on a distinguished road
hi dbarath did you get your turret problem resolved if not give me a call at 647 308 3375
Tags
duplomatic turret, locking control switch, proximity switch, storm cnc 300, turret unclamped
Need Help!- Tornado 300 Duplomatic Turret yarpo Colchester Tornado lathes 4 11-13-2009 06:35 AM
DUPLOMATIC TURRET TIM_SMALL General Metal Working Machines 1 11-07-2009 04:11 PM
New Guy need Duplomatic Turret help raygun Cincinnati CNC 10 09-19-2009 02:00 PM
Appreciate Help - Duplomatic Turret Fault Tony2pies Cincinnati CNC 1 08-31-2009 10:56 PM
Newbie needs help with Duplomatic Turret raygun General Metal Working Machines 0 11-26-2008 02:46 PM
