Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Colchester Tornado lathes
Colchester Tornado lathes Discuss Colchester Tornado lathes here
Old 01-11-2011, 10:59 AM
Nastyzen is on a distinguished road
Battery charging??
Hello boys n girls!
I have the Colchester Storm a-50 lathe model with Fanuc 21iT.I have not run the machine for a while and I was wondering about my x and z axis batteries going dead.Are these batteries rechargable and get recharged when the machine is running or are they like your regular flashlight bats and just get changed when they run low?They are Panasonic lithium BR-2/3AGCT4A 6V with 4 batteries in the pack.
Thank you
Old 01-11-2011, 02:27 PM
underthetire is on a distinguished road
Lithium, not chargeable. Very expensive. I made a lot of money in the past installing the fanuc D cell battery boxes. Worth while upgrade, once the lithium batteries go, it about 75 bucks for the batteries + overnight shipping- so ~100 bucks every year or two. The battery boxes were 60 bucks, about an hour to cut and mount in the machine, and 10 bucks a year from your local grocery store.
Old 01-11-2011, 03:03 PM
D cells!!?Now why didn't I think of that!That's brilliant indeed.
So if they are not rechargeable then letting the machine run now and again won't do a thing?
underthetire you are awsome!!Thank you so much for the info.
Old 01-11-2011, 03:07 PM
Not for the batteries, but it's good for the slides to get moved around. It will keep things lubed, loose, and ready to go.
PS, I have seen guys put those 6volt lantern batteries in the machines to. The fanuc box was just a little cleaner.
Old 01-17-2011, 04:06 AM
MarineMachinist is on a distinguished road
Also, remember that when changing the batteries, make sure the machine is on... otherwise it will dump the axis memories... I learned the hard way. . .
Old 01-17-2011, 07:39 AM
He he!Thank's for the warning but I already knew about that one.Friday I went and picked up the goodies to switch over to D cell alkaline batteries.When I get around to it I will try and post the mod that I came up with.So far about $30.00 bucks spent.
Old 02-21-2011, 07:17 PM
So this is what I came up with for 30 bucks.Thanks a lot again.
Zen
ID:	127090   Click image for larger version
ID:	127091   Click image for larger version
ID:	127092   Click image for larger version
ID:	127094   Click image for larger version
ID:	127095   Click image for larger version
ID:	127096   Click image for larger version
Acramatic backup memory battery charging problem cnc1000 Cincinnati CNC 8 03-17-2010 01:00 PM
Solar power for charging USB devices and recyling Shotout Environmental & Alternate Energy 1 06-29-2009 10:37 PM
battery alm Drye-123 Fanuc 4 12-18-2008 08:26 AM
charging by hour Max Richards WoodWorking 3 06-25-2007 05:48 AM
Super charging. MrWild Stepper Motors and Drives 8 10-24-2005 06:29 PM
