Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Colchester Tornado lathes
Colchester Tornado lathes Discuss Colchester Tornado lathes here
Old 11-15-2010, 04:11 PM
Red Cap is on a distinguished road
Colchester A110 MFB1000 Barfeed problems
I have a problem wih a Colchester A110 Tornado lathe fitted with a MFB1000 barfeed.
The problem has only occurred after the machine and barfeed have been moved (about 10ft and turned 90 degrees).
When M78 is called the following alarm is displayed
"Al 112 - Division by 0 was specified".
I have read the fanuc 21iT manual and the program has not changed since the machine last worked.
Program
G21 M90
G92 S1500
T1111
M05
G0 X20. Z.3
M9999
Z0.3
M19
M78 - ALARM 112
G0 V2.3 Z.3
G4 X0
M79
W5.0
M99
My guess is the barfeed set up, so any ideas on this or any other possible solutions gratefully recieved.
Thank you in advance
Red Cap
Old 12-04-2010, 04:45 AM
scott81 is on a distinguished road
when we got a barfeeder installed on our 220 we had a similar problem when it reached M82 (end of bar check) in the prog it stopped and alarmed, for some reason it worked when we added M82 in the next line. ie:
M82
M82
Tags
al112, barfeed, colchester, tornado
Clausing Colchester problems???? banctecbobn General Metal Working Machines 1 11-04-2010 08:00 PM
Need Help!- smw barfeed Hash01 G-Code Programing 1 08-07-2009 01:05 PM
Need Help!- barfeed 300 jz25180 Haas Lathes 4 06-15-2009 08:39 PM
Need Help!- Programming SMW barfeed on sqt-250 6thAxis Mazak, Mitsubishi, Mazatrol 1 08-07-2008 11:48 AM
LNS Barfeed Lazzer65 General Metal Working Machines 4 08-13-2006 04:22 AM
