Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Colchester Tornado lathes
Colchester Tornado lathes Discuss Colchester Tornado lathes here
Old 07-25-2010, 02:10 PM
hmc710 is on a distinguished road
Same tool - different cuts ?
Hi All,
I am new to my Tornado 200 w/Fanuc O-T control. I am learning (?) how to check and set tool offsets ie: T0101 = Tool 1 Offset 01. Wrote a program to make a cut and then I measure and check the offsets. I have a program that uses T0606 and makes a G71 rough cut canned cycle and G70 finish cut which measure ok. Then I use G01 with T0606 and program a different rough and finish cut and the cut is .020" larger in dia. (.936 is actually .956" dia). That's when I did the tool check program. Called T0606, made a 1.100 dia cut and it measures 1.102" As a check, I called up the 1st program, called up the oversized cut portion with T0606, stopped the program and used the jog control to move the tool to the part surface with a piece of paper to check clearance. Position reads .937" but measurement is .956" I have not changed the work offset or datum shifts that I know of. I start both programs with G92 and G40. I've been reading the manuals but........Any suggestions for a new guy?
Thanks.
surface flowline tool cuts wrong direction timmydabull Mastercam 5 08-03-2009 07:48 PM
X2 tool entry cuts edge of pocket paulpounds Mastercam 1 03-24-2009 02:01 PM
Looking for geometry on a dimond cutting tool for surface cuts Craigpat Solidworks 0 02-10-2009 08:53 PM
frustration....plasma cuts off during cuts any ideas? gpnjuice CNC Plasma and Waterjet Machines 2 11-18-2007 06:45 PM
M00 within cuts with same tool shawncnelson Mastercam 3 05-05-2006 06:38 AM
