Results 1 to 2 of 2
Thread: Colchester CNC 350 gib adjustment?
    Feb 2006
    England
    Hi all,
    Not a Tornado, but forerunner..
    1991 Colchester CNC 350. Had a little 'accident' last week resulting in the tool turret out of alignment to the head. Nothing really serious, but needs adjustment. We slackened off the bolts to swing adjust the turret back into square with the machine, and in the process of doing so noticed that the saddle had so much play on the x axis slideway that it rocks a bit from left to right. I dug the manual out and discovered there's a screw to tighten up the gib plate which I duly did, it seems to have helped but there's still a bit of play - is this normal for CNC lathes? should any movement be absolutely minimal, or would you expect a little?
    Although old, the machine has been working pretty well to date.
    Any advice gratefully received.
    Cheers all.
    Dec 2008
    Sweden
    You can tighten the saddle play screw real tight. If you have a x axis play after doing so, its probably the x-axis bearings. No big deal. I am about to change these bearings on my machine soon.
  1. Need Help!- colchester 100 with fanuc control
    By newcol in forum Colchester Tornado lathes
    Last Post: 01-04-2009, 11:20 AM
  2. Buying a used Colchester
    By ragman in forum Colchester Tornado lathes
    Last Post: 09-05-2008, 05:01 PM
  3. ID Colchester Lathe
    By dwl in forum General Metal Working Machines
    Last Post: 05-24-2008, 03:23 PM
  4. Problem- colchester cnc 200l
    By briggs in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 04-07-2008, 02:29 PM
  5. Colchester Tornado
    By rrbmachining in forum Suggestions for the CNCzone.com site.
    Last Post: 01-26-2008, 09:33 PM
