| Colchester Tornado lathes Discuss Colchester Tornado lathes here |
Hi all, Now that you helped me get the machine running, I've been going through the program manuals and making moves. I can't seem to make a G01 move in X & Z axis , like a 45 deg cut. It will traverse simultaniously in G00. For example: Going from memory here on the program I have been editing G00 X10 Z12 G95 G96 T00 S1000 F0.003; START POSITON T0100;TOOL SELECT X6 Z6 T0101; RAPID WITH OFFSET G01 Z5; CUT IN Z DIRECTION @ Feed X6.5 Z6.5; CUT A 45 DEG CHAMFER. The tool only moves in the Z direction. Is this common, am I doing somthing wrong (working off my limited mill programming) or are non linear moves all done with G codes? I am also looking for the location of the Tool data and offset info. Right now I call up a tool and make a hopefully safe move and take some measurements. Thanks, HMC |
My "faulty" linear xz move was an illusion. I could see the dro indicate movement in both directions, I could not see it. (Was not cutting a part, just watching) The default programming is Diameter for Z and I'm stuck on my Acad XY system so I had to double my X moves to get where I needed. Anyway, success! made my first part by hunt & peck method and fudging the moves by an offset value to get the tool where I needed it. Still need to work on that learning curve. Also trying to get tailstock to move in and out. The chuck opens and closes like it should and I assume the control would allow the chuck or tailstock to be commanded manually. Thanks again for all the help, maybe today I'll run it at 100% speed ![]() HMC710 |
| Need Help!- Tornado 200 Fanuc ot not responding spindle and turret | tkea | Fanuc | 10 | 05-21-2012 12:29 PM |
| Newbie- Tornado 300 with Fanuc O-T | kama | Colchester Tornado lathes | 7 | 03-04-2011 02:11 AM |
| Colchester Tornado Fanuc 21i-t | Stebedeff | Fanuc | 2 | 11-07-2010 07:43 PM |
| Need Help!- tornado 80 | kirkchabot | Colchester Tornado lathes | 2 | 01-04-2010 01:51 PM |
| Colchester Tornado 200 Fanuc OT Control - Turret indexing problem | JohnWD | Fanuc | 10 | 12-29-2009 09:10 AM |
