- backup
backup
Hi how do back up your parameters on a 1997 Colchester Tornado 100.
Re: backup
Step 1: Set up your Personal Computer (PC) or laptop to receive data. (click here for information on RS232 setup)
Step 2: Punch out NC Parameters as follow
Select EDIT mode.
Select PARAMETER screen (by pressing PARAM/DGNOS key once).
Press and hold EOB key while pressing OUTPUT START.
* Note: OUTPUT will flash in the lower right-hand corner and NC parameters will be output.
Step 3: Punch out PMC Parameters as follow
Select EDIT mode.
Select DIAGNOSTICS screen (by pressing PARAM/DGNOS key twice).
Press OUTPUT START.
Step 4: Punch out all NC Programs as follow
Make sure parameter no. 10 bit#4 = 0 (unprotect programs 9000 ~ 9999)
Select EDIT mode.
Select PROGRAM Memory screen.
Key in “O-9999”.
Press OUTPUT START.
Step 5: Punch out Offsets as follow
Select EDIT mode.
Select OFFSET screen.
Press OUTPUT START.
- backup
- You may not post replies
- You may not edit your posts
Forum Rules
