Problem Fanuc 20 T Control
Results 1 to 2 of 2
Thread: Fanuc 20 T Control
    Nov 2011
    Spain
    Default Fanuc 20 T Control
    I have a colchester cnc lathe fitted with a Fanuc 20 T control (1996)
    I am trying to eliminate a random 401 vrdy axis error on the Fanuc control.
    I have noticed on the Fanuc Alpha Power supply when I removed it to check it internally that there is no large, 100 amp fuse fitted in the space at the top of the power supply,
    is this normal ?
    The machine seems to work ok without a fuse fitted but is this standard?
    The Spindle drive and servo amplifier both have this 100 amp fuse fitted, so why not in the power supply?
    I have removed the servo amplifier to check it out as well and have noticed that there is a space for a small battery pack but there is no battery fitted,
    Do I need to install a battery or will the control work fine without it?
    When the machine is behaving itself then it seems to work ok, but would it have less random errors with these 2 parts fitted?
    This is the fuse fitted in the spindle and servo drive, maybe the power supply should have the same fuse?Fanuc 20 T Control-cr2ls-fuse-jpg
    May 2016
    United Kingdom
    Default Re: Fanuc 20 T Control
    Can you send a pic of the power supply ?
    I would suggest its connected to another problem as the electronics were tempramental
Fanuc 20 T Control
Fanuc 20 T Control
