- colchester cnc 2000l parameter
does anyone have the full parameter files backed up. I would be thankfull if anyone could e mail them to me.
thank you all
Re: colchester cnc 2000l parameter
Flies Fast
use the "Search" feature.... LINK
wiring diagram does anyone has the wiring diagram as well
Superman I did already. two problems left spindle not working and I have an 8 staion duplamatic .. in your file I just found 4 duplamatic parameter and 8 staion sauter.
Have you initialised the spindle on the rear of the machine, on some of these there was a separate button to bring on the spindle as for the duplomatic that is just a diagnostic turn on
I started working on the machine from the point the monitor did nt even turn on. with a lot of problems starting from memory loss till many boards had to be cleaned. had problem with door closed switch and many more. till now never had a wiring diagram nor the parameter from superman. was later able to enable the plc view. so at least could work my way through that. my problems now are the turret and the spindle not working.
else i believe everything is working. In supermans parameter 8120 parameters where missing where motor is and direction are described. till i changed them i got 417 427 servo error
- You may not post replies
- You may not edit your posts
Forum Rules
