G75 and Parting Off
Results 1 to 2 of 2
Thread: G75 and Parting Off
    Jun 2005
    Default G75 and Parting Off
    Hi
    I am having problems with long cuttings when parting off, once the tool is in the about 5mm deep I get nice clockwork shavings but prior to that I have long shavings, that take up a lot of space.
    Start diameter is 160mm, and finish is 143mm, part off tool is 4mm wide, CSS 150m/min, feed 0.075mm/rev, material 1020 mild steel, qty 5,000 off.
    I think I should be using G75 instead of G1 that I could then set a peck cycle, but not sure on how to go about it?
    At the current rate I fill a 44 gallon drum in a day with swarf from the parting cycle alone .
    Lathe is a Colchester Tornado 200.
    Any suggestions greatly appreciated.
    Best Regards
    Burgs
    Jun 2005
    Default Re: G75 and Parting Off
    Hi
    Sorted it out with G75, reduce the shavings by half with pecking but need to talk to insert/tool suppliers for better chip control.
    Burgs
G75 and Parting Off
G75 and Parting Off
