ATTENTION! L. Sakthivel
Results 1 to 4 of 4
Thread: ATTENTION! L. Sakthivel
    Registered 600Service's Avatar
    Mar 2010
    UK
    Default ATTENTION! L. Sakthivel
    You sent me a PM, but I cannot reply because your PM box is full!
    Answer:
    Quote Originally Posted by L. Sakthivel
    We are having Colchester CNC Lathe 2000L Model with Sauter 8 Station Turret and Fanuc 0T control. Parameters are corrupted and we entered the Back up parameter.
    Now machine is working but turret not working in Manual as well as Auto Mode. if we are calling the the Tool code in MDI Mode, Tool code completing without changing the Tool and Displyed the Called tool in CRT tool position.
    We feel it seems to be the PC Parameter Setting problem. Can you help us.
    Sounds like the diagnostic for the turret is not set. I think D500 should be set to 00001000.
    Apr 2007
    India
    Default I think D500 should be set to 00001000.
    Dear Sir
    D500 we set the Same & we tried for the other options also related to turret no improvement.
    L. Sakthivel
    Email:info@premierengrs.com, website:www.premierengrs.com
    Feb 2011
    india
    Dear Sir,
    we have the same problem, kindly help us if your is solved.
    thanks and regards
    devender sharma
    info@cncsolutionindia.com
    Feb 2011
    india
    Dear Sir,
    Kindly set d500 100
    if you need nc and pc parameter
    i can send you
