Page 6 of 6 FirstFirst ... 3456
Results 61 to 68 of 68
Thread: Newcastle CNC BBQ!
  1. #61
    Jul 2007
    I will set a date in the next week or so.
    Try and get the word out to other people that you know.
    I will also post a few links up for some of the parts I showed on the weekend.
  2. #62
    Mar 2011
    Hi Guys.
    Just a few questions if anyone can help. I have my DIY CNC running well and have finished a few projects. I am now doing some 3D stuff and would like to know which bits to use to give a smooth finish. I am using aRyobi trimmer as a spindle and it works great but I need to get a decent finish on jobs.
    Any help would be much appreciated.
    Regards Greg.
  3. #63
    Jun 2008
    Hi Greg.
    I use bits from Precision solid carbide tools for woodworking and metal forming.
    not the cheapest but very good, for 3D work use 1/8 or 1/16 for real fine work.
    Keep in mind when you reduce a 3D design you must use smaller bit, the same, if you enlarge the design you can use a larger bit.
    Gary
  4. #64
    Mar 2011
    Thanks Garry.
    Should I be using bullnose to finish with??
    Regards Greg
  • #65
    Jun 2008
    Hi Greg.
    Cut3D makes several tool path, You have to do a roughing tool path first, I always use a
    6.35mm(1/4") square end up spiral cutter, McJING Tools Online have a good selection at the right price they are
    Chinese but good quality.
    Your next get your finishing tool path and use your 1/8 or 1/16 bull nose cutter.
    For each tool path Cut3D will ask you to nominate the cutter you want to use.
    Gary.
  • #66
    Apr 2007
    Hi guys...
    Messing about with a Chinese 6040 machine up here at Maitland.. playing with 3D cutting at the moment.. Does the Newcastle group still meet?
  • #67
    Jan 2009
    hasn't met in a while. must be time for another BBQ I think.
  • #68
    Jul 2009
    Another Newy BBQ.....?
    Yeah, I think you're right Brent......... it's been about 5 months since the last (first) one. I wonder if Todd (Hellman) is listening in...... Nice central location......
    - Craig.
    my JOES2006 build thread - http://www.cnczone.com/forums/showthread.php?t=106995
  • Page 6 of 6 FirstFirst ... 3456
    1. Just IN- Newcastle or Sydney area? Please read this...
      By hellman81 in forum Australia, New Zealand Club house
      Last Post: 05-05-2010, 03:59 AM
    2. Replies: 0
      Last Post: 03-10-2009, 07:57 PM
