02-03-2010, 05:15 PM
3D AutoCad DWG to suit CAM Programmer | | G'day Mates and Friends,
I have a question concerning how I should draw/section/dimention/annotate, etc. drawings of complex 3D shaped parts in order that the CNC Milling Center Programmer will not be troubled with insufficient data or views of the project.
I have individual parts on their own drawing and they pose no problem. But, the bulk of the item is somewhat barrel-shaped with an array of similar "veins" parallel to the center axis starting small at the ends and expanding toward the middle. The entire profile from end-to-end is identical, only scaled to create the "small" to the "large" viens.
I have the "barrel" designed as "Upper" and "Lower" mirrored halves.
I have experience in basic 2D CNC Machining, and Turning as well as programming. I do know 3D requires quite a number of data points on complex shapes, scaled identical profile or not, to create a decent cad drawing file for the CAM engine to secessfully create the item that is represented in the CAD drawing File.
I cannot divulge any more details of the what or how the item will be used or for what...sorry.
For a drawing of a coconut with several bananas fitted around it(bananas being small at each end and larger in the middle) how much detail should I concern myself with as to the data profile of the bananas from small to large sections?
Remember, I'm mirroring the one end for the other end...
I am sure I am making this to be much more complaced than it is.
I just want to have all my ducks/bananas, etc. in a row for the poor chap machining this thing. (It likely will be done in AU)
Thanks for your advice, and Cheers fellow Chip Makers.
Woody...the shipping guy...
__________________ For Complete Internet Safety, get AVG Internet Security with 2 year license for $79.99 and AVG Identity Protection is included. avgsalesteam@gmail.com (662) 333-3047 |
