Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 11-25-2009, 04:45 PM
REVCAM_Bob is on a distinguished road
Something better than plexiglass?
I have a problem and I thought this might be the place to ask....
We have a cnc wet grinder, and are always fighting the coolant splashing over the sides of the magnet area as the enclosure is not high enough.....
So we are constantly using pieces of 1/8 plexiglass stuffed in or bolted to the side, front and back of the table.... the problem is the plexiglass is difficult to cut or drill with out breaking it, and it is always cracking so the whole setup looks hodge podge.
Would anyone have a recomendation for a better material that is easy to cut / drill etc. but is still some form of light weight material?
Thanks!
Old 11-25-2009, 04:59 PM
bhoff is on a distinguished road
You could use polypropylene or polyethylene to do that. Its light weight and is available in sheets. Its flexible so it wont crack or chip like the polycarbonate or acrylic.
Short of setting it on fire or forking it with a hi-lo it should last years.
Old 11-25-2009, 05:06 PM
austin.mn is on a distinguished road
For splash guards, I have been using coroplast. Its the plastic cardboard stuff they use for signs. I buy it from the sign shop $15 for a 4X8 sheet. Its cheap, light weight and easy to cut. Works well for me.
Old 01-18-2010, 03:35 PM
SIMONSIGNS is on a distinguished road
Polycarbonate or aluminium composite should work.
That composite is great stuff. lightweight and very user friendly. we use it all the time now.
Old 01-22-2010, 11:13 PM
Gold Member
RomanLini is on a distinguished road
Plexiglass (acrylic) drills perfectly with a blunt drill bit. It can help a bit too using a pilot drill about 40% of the final drill diameter (yes the pilot drill should be a bit blunt too).
It's funny when people use their razor sharp new drill bits...
Old 01-22-2010, 11:43 PM
Polycarbonate, also known as Lexan or Tuffak.
Do I get my message across?
Polycarbonate is far more impact resistant than plexiglas.
Old 01-25-2010, 07:48 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
also known as HYZOD or PALTUF.
Your safety glasses are made from POLYCARBONATE.
Bullet-proof "glass" is made from specially laminated POLYCARBONATE
Do I get Geof's point across?
www.integratedmechanical.ca
Cheap CNC-machine for cutting plexiglass ? BoXon DIY-CNC Router Table Machines 10 01-18-2010 06:20 PM
Need Advice: Routing Plexiglass animuL Glass, Plastic and Stone 8 07-30-2009 10:17 AM
rfq-----custom black plexiglass sheet tooldzinr Employment Opportunity 6 05-28-2009 10:16 AM
Feedrate and RPM for a Plexiglass mold gabi68 Moldmaking 5 04-11-2008 09:49 PM
Plexiglass instead of MDF slickrick DIY-CNC Router Table Machines 6 03-30-2008 09:11 AM
