| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
I am cutting melemine laminated chipboard ( 16mm) and it is chipping along the bottom edge of the board. I am using a 1/8th straight bit. The bit is new and sharp. It has been suggested I use a chip breaking bit after my initail cut but that sounds like it would be impractical for me since I dont have a tool changer and dont really want to do the same cutpath a second time. Any suggestions. |
| You could try to apply tape, or if you can score the bottom before you cut through that would work to. I use to work at a exhibits company building exhibits, usually routing did'nt cause chipping but cutting with a saw blade did, depending on the type of blade used.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| How about taking a finishing pass? Have you tried a spiral endmill? (That'd move the chipping to the top maybe.) Climb cutting? (on a finishing pass that'd probably not chip out on both sides. I've cut a little of this stuff and thats what I ended up having to do.
__________________ Nathan Last edited by anoel; 03-17-2005 at 08:46 AM. |
| They do sell a special bit the cuts up and down, for melamine. "Three flutes upcut & three flutes downcut. This tool was designed with extremely high feed rates in mind. Primary usage on double laminated particle board. Secondary usage suitable for finish cuts in solid wood and other dense materials."
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com Last edited by CNCadmin; 03-17-2005 at 09:39 AM. |
| You need a compression spiral, Benny. I use these at work. http://www.vortextool.com/standard/p...fm?groupID=273 You can find cheaper ones, but these are the best I've used.
| Do you have to use a 1/8" bit? A larger bit will probably cut cleaner due to less deflection and chatter.
| Kcam Cut depth | 47MLB | Kellyware CAM | 6 | 01-18-2012 02:04 PM |
| rotary 4 ax depth of cut q. | nervis1 | Mastercam | 4 | 03-24-2005 05:34 PM |
| cut single, cut auto and cut all??? | fastolds | BobCad-Cam | 3 | 10-06-2004 09:15 AM |
| PICS - BOAT HULL CUT WITH CNC | ninewgt | DIY-CNC Router Table Machines | 16 | 08-02-2004 07:21 PM |
| Can you cut Al. with a wood bandsaw | CactusChip | General Metalwork Discussion | 5 | 11-20-2003 04:45 PM |
