Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 07-22-2009, 11:10 PM
DingbatCA's Avatar
DingbatCA is on a distinguished road
Best stepper driver? Gecko, Keling...
What is the best stepper motor driver from the money? How do they rank? Is gecko the best, or does Keling do better? I would guess my hobbyCNC board is holding up the bottem end?
Old 07-22-2009, 11:32 PM
The CNC Man is on a distinguished road
Hello
I need a driver board to and wondering the something, I have been looking at the HobbyCNC pro driver board 4axis kit with 4 305oz motors, cost about $350.00 with shipping, Link http://www.hobbycnc.com/products/hob...oard-packages/
but I'm just not sure which way to go, I'm building a 4ft x 4ft CNC, I will post some Pict's when I start putting it together if anyone is interested.
any help would be appreciated.
Old 07-22-2009, 11:46 PM
DingbatCA's Avatar
I have the HobbyCNC Pro board. For the price, 25$ per axis, I do not think it can be beat.
After all the time I have spent with the hobbyCNC board, I would rather have bought a G540. I blew out two HobbyCNC board's. The G540 has built in protection. The HobbyCNC board has a nasty problem with Mid-band resonance. The G540 has built in compensation.
If you are just starting, go for the cheap HobbyCNC board. But, if you a little extra cash and get a G540, do it.
http://www.geckodrive.com/product.aspx?c=3&i=14469
My question: Is there any thing better, for the cost?
Old 07-22-2009, 11:54 PM
veteq is on a distinguished road
What is the best car?
You really need to read a bit more overhere, there are so much parameters that determin witch is the best drive.....
regards,
roy
Old 07-23-2009, 08:12 AM
ger21's Avatar
HobbyCNC is the best bang for the buck, but Gecko makes the best performing drives.
Old 07-23-2009, 11:48 AM
amplexus is on a distinguished road
In terms value, price, performance, resale value etc gecko is unbeatable, they not only perform well, the 540 and 203v vampire are nearly unkillable.
Amplexus Bob
Old 07-23-2009, 12:03 PM
pminmo's Avatar
pminmo is on a distinguished road
DingBatCA,
Your question needs more qualification, kind of like asking what is the best vehicle to drive. A person might recommend a Porsche, when the user forgot to mention it needs to haul a half ton of dirt and rock.
Post your application and the mechanics, then the question can be appropriately answered.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 07-23-2009, 02:39 PM
DingbatCA's Avatar
OK, my application.
Looking to have a finished cutting area of about 3x2x1ft XxYxZ. This will be my 7th CNC to build. All other have used a HobbyCNC pro board. It is now time to move on from plywood and 8020 to steel.
Currently in the first stages of design. Making it from steel, for the most part. The main supports are W4x13 I-Beams.
In truth, most of my time has been spent on the motion issue. I started off with all thread, but it died. When I moved on to my 5~6th CNC's I used ACME lead screws. But was still disipointed as the nuts wore out. I would like ball screws, but they cost WAY to much. So I spent many days trying to get around the cost/presition problem and came up with this.
I call it a roller screw.
It is all 1-1/4IN 0.2 lead ACME lead screw. Three support rollers and the main going right through the center. The picture is a bit out of date. Newer version solves the issued of needing to tightnin the 3 support screws around the main.
The new CNC, R7, will have dual X's. So, a total of 4 axis's. I wanted to use a G540, but I quickly realized that do to weight issues, I need to go bigger. Now trying to find the best solution driver for the cost.
Old 07-23-2009, 03:10 PM
the4thseal is on a distinguished road
you have figured out how to make a roller screw? really? i have used commercial versions in work but home made? bravo, show me how.please.
Old 07-23-2009, 04:45 PM
inertia
Hey Dingba,
sorrry for my crude reaction, very nice design you got over there.
really, weight isn`t the problem at all when moving horizontal.
Let`s say, you need to move 200 Kilogram with a speed off 2meter/min.
Sorry for the metric system, but its for the example, you can scale it)
You would only need 200 x ( 2 / 60 ) = 6,7 watt
and for acceleration off 0,1 G. 200 x 0,981 = 196,2 Newton
This is all nema 17 territory for a stepper, since a ballscrew with 0,2 lead with 0,5 Nm delivers 500 Newton off thrust at the table. You have an extra off 300Newton.
But then there are bigger problems, Inertia and friction.
If you want to know for sure you would need to know the inertia off the system and we cann calculate the rest for u, best would be to calculate all the needed force and choose a stepper times 2. This to keep the inertia off the stepper at lowest and have the biggest possible acceleration.
For the drive i would say a gecko is best, since it has nice mid-band res. and is unkillable, also it morphs to full step at higher RPM.
If you cant calculate all this, smartest thing would be to go with linear bearings and ballscrews, the Chinese are allready cheaper then most acme screws.
Regards,
Roy b.
  #11   Ban this user!
Old 07-23-2009, 05:12 PM
DingbatCA's Avatar
Acme screws are cheap, $10 a foot, about $11.5 after shipping and tax. Last time I looked a ball screws, even cheap ones, they were in the $200+ each. I need 3, two 4.5ft and one 4ft. Do you have a cheap vendor?
Currently using V-groove's, but I am early in the design and could be convinced to switch to linear bearings, and ball screws. :-) It all comes down to cost. The roller screw design is costing me about $50 each.
Inertia, no clue. Need to get the design much closer to done to get that information.
So NEMA 34's may be overkill... I am good with that ;-)
  #12   Ban this user!
Old 07-23-2009, 05:47 PM
pminmo's Avatar
Two nema34's on the same axis isn't overkill it is severe overkill...... Look at www.roton.com for reasonable prices on screws, including ballscrews.
Gecko 203Vs and Keling 1200ozs getting VERY HOT! idtkid DIY-CNC Router Table Machines 7 04-30-2009 01:46 PM
Gecko 540 Package from Keling. Good Choice or Not???? JeLC DIY-CNC Router Table Machines 1 03-02-2009 06:20 PM
Need Help!- Gecko 540 Mach 3 Keling Steppers on a Taig gunlocators Gecko Drives 4 02-21-2009 02:58 AM
keling Stepper Motor Driver KL8078 marcusb Stepper Motors and Drives 5 02-22-2007 09:12 AM
Picking a Gecko Stepper Driver? pfeist Gecko Drives 2 09-29-2005 11:04 AM
