Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 07-09-2009, 10:53 AM
ironmountain is on a distinguished road
Multicam is not powering up properly
I resently purchased a used Multicam MG Series router table. The table looks to be in great shape. however, i am have some problems when powering up..
The pendent seems to be working improperly... the shut off switch is working properly and the spindle switch works as well. But the display reads "MULTICAM KDM V3.02" and it will not allow me to home it, the buttons are non active.
When under power everything seems to power up but the axis motors won't run and the spindle will not run.
I have read post by dasiydog with a simular problem.
Old 07-09-2009, 11:00 AM
SCRAPWOTSCRAP is on a distinguished road
To home a MG series after power on, press shift key (up arrow on right side of keypad) followed by home key (green key showing right angle with 2 zeroes) machine should move to home position.
Last edited by SCRAPWOTSCRAP; 07-09-2009 at 11:02 AM. Reason: apparently forgot my left from my right
Old 07-09-2009, 11:07 AM
still is unresponsive
Old 07-09-2009, 11:28 AM
Does the software loading screen clear, after power up?? After it loads does it go to a "position screen" showing postion of the axes, etc...?
Old 07-09-2009, 11:56 AM
As soon as i turn the switch to the on position the display reads "MULTICAM KD V3.02" and nothing else
Old 07-09-2009, 11:58 AM
oh... the display does not clear.... it continues to display "MULTICAM KD V3.02"
Old 07-09-2009, 12:02 PM
Does your keypad plug in via a connector? If so, power down, unplug connector, check the pins, reconnect and then power up again.
Old 07-09-2009, 12:23 PM
Pins and connections look good. I rebooted and nothing has changed
Old 07-09-2009, 12:28 PM
Well I guess from there I would have to power down, check all the connections to the main board in the cabinet. Where are you located?? Your screen name hints at the U.P.
Old 07-09-2009, 12:31 PM
I think that is the next best step. I am in Richmond, VA
  #11   Ban this user!
Old 07-09-2009, 12:38 PM
I had an MG series give me some similar problems awhile back, eventially it was determined that the keypad (pendant) was bad . Be advised I'm no expert on Multicam machines, but have some experience with them. Best to check the obvious first before getting out your wallet. Have you talked to anybody at Multicam service for your area?
  #12   Ban this user!
Old 07-09-2009, 04:23 PM
One of Many is on a distinguished road
A couple things come to mind. If this has a tool changer, make sure the 10amp breaker in the cabinet has not tripped. You also must enable the drives with the pendant rotary switch before it can be homed. At least that was the way our MG pendant was.
The manual should walk you through the startup procedure.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
powering a stepper with an ATX PSU ryckmans_t Stepper Motors and Drives 14 11-29-2008 04:53 AM
6M Powering up alarm TR MFG Fanuc 9 11-17-2008 04:14 PM
Need Help!- powering up hardinge DV-59 logos General Metal Working Machines 1 07-07-2008 07:10 AM
powering down the control Joe Miranda Milltronics 3 04-12-2008 08:48 PM
Fanuc OT-C Not Powering Up JerryH Fanuc 4 08-22-2007 06:34 AM
