Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 04-30-2009, 09:49 PM
aaron p's Avatar
aaron p is on a distinguished road
Where to find military surplus hardware?
Im looking for 12point stainless and normal steel flange head fine thread nuts. Ive got a contact that can get military surplus, but im trying to find out where he is getting it from. Anyone know where I can find these at? Ive googled all I can and nothing but ammo canisters and body gear. Even Boeing or Lockheed would be good.
"We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
Old 05-01-2009, 06:42 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Still working on the header problem?
Just for conversation sake, if I remember right, you wanted a 5/16" UNC thread, probably for aluminum heads where you don't want to be screwing bolts in and out, so you naturally use studs on a true racing app... Right?
But then you wanted a 5/16" UNF so that you could use a 12 point nut so that you wouldn't have clearance issues with the primary tubes? If memory serves me?
So, if I remember right, problem is you need a stud with enough clearance on the mounting side that the fastner clears the primary tubes of a quality header... Forgive me if I'm wrong!
If the above is all true, what I would do is a tear out test of a 5/16" UNC to 1/4" UNF, the 5/16" side threaded into aluminum, the 1/4" side secured with a standard 6 side nut, see if the aluminum fails before the stud fails at room temps... But that's if a 1/4" 6 side nut would clear the primaries, and would require a washer that is ground to clear the primaries.
But, I would totally agree, even if the aluminum would tear out before the stud would fail, if you were trying to market a new product to solve a timely problem, it would be a hard sale to the general public.
Just a thought, if nothing else, a glorified bump.
MC
Old 05-01-2009, 12:06 PM
aaron p's Avatar
Not only for headers, but I need 12pt nuts for some other projects im working on. If I can cut my costs down, I can drop the final price for customers.
machining in the military MBG CNCzone Club House 11 04-13-2009 05:51 PM
Looking for surplus Hack 80/20, TSLOTS and other Aluminum Framing Systems 0 10-16-2005 11:05 AM
Those pesky military connectors... murphy625 General Electronics Discussion 4 03-18-2005 12:56 AM
Where to find surplus Tslots or 80/20 samualt 80/20, TSLOTS and other Aluminum Framing Systems 8 11-05-2004 02:04 PM
PSU 25V 30A on surplus Konstantin General Electronics Discussion 6 08-31-2004 05:14 PM
