Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 03-26-2009, 11:57 PM
BasicFox is on a distinguished road
Mill PCB with cnc, optimise software
milling an smd pcb is quite difficult...
my first attempts to mill the openservo pcb were not so good. The pads where too small. So i have created a program that strokes each pad until it reaches an other path and then leaves only one pixel between them. You just have to create a black/white 24b bitmap of a pdf with photoshop or an other application and load it into my program.
This is the result:
http://www.basicfox.com/Top-Big.gif (Top layer of V2 Openservo PCB)
http://www.basicfox.com/Top-Big-Routed.gif (New Bitmap after 40px stroke)
Specify a zigzag direction if your cnc has backlash on one of its axes (like mine does)
After that u can save it as a .tap G-code file and load it into your cnc milling software.
You also can drill the holes automaticly:
http://www.basicfox.com/Holes-Big.gif (Holes of V2 Openservo PCB)
http://www.basicfox.com/Holes-Big-Routed.gif (after you saved the G-code)
The program searches for the middle of each black dot and then only marks the middle of it.
If you are interested, you can download the program here:
http://www.basicfox.com/BitmapnaarG-code.exe
it requires the .net framework
Need Help!- Can I use Mach Software on my Mill? mgb1974 Mach Software (ArtSoft software) 4 02-02-2009 11:11 AM
Newbie- What type of Mill and Software to Buy???? Buttabill General CNC (Mill and Lathe) Control Software (NC) 0 06-06-2008 12:08 PM
PCB Mill software nophead00 OpenSource Software 6 05-31-2007 02:13 PM
Which CNC Mill and what software? MaxxMan-X Knee Vertical Mills 16 04-18-2004 12:25 PM
