Results 1 to 4 of 4
Thread: Good ole fashion Noob question about motors for my design
    Mar 2009
    Question Good ole fashion Noob question about motors for my design
    Thanks for all of you who view this and reply..
    Thanks also to all of you have posted in other threads that I have read and aided in my education thus far...
    Now to my question...
    I have recently designed, and built a scale model, of my 5 axis machine.
    However, it has become clear to me, that using the geometry, paths, and design, is going to require me to use two (2) motors to move my Z axis.
    The use of one motor in the center (as typical in most designs) will not work as it will be in the middle of my work area, and the use of one motor on one side will torque the axis...
    Image if you will that the Y axis is in the horizontal portion of the letter H.
    And the Z axis is the twin vertical portion.
    Question: Is it simple enough to configure, sync, and drive twin motors?
    Thanks for the help!
    Dec 2004
    I just checked and in mach3 it should be really easy. just go to slave under the config tab.
    But it all depends on which software you are running.
    Mike
    Mar 2009
    I intend to use mach 3...
    That is an awesome solution too...
    I was hoping I would not have to build a dual/tandem controller...
    I am guessing mach3 will require that to be a second controller?
    Mar 2003
    Shelby Twp, MI....USA
    Toy need two identical drives, motors, and drive systems. Then you just check a box in Mach3 and your all set.
  1. noob question
    By manufan in forum Post Processors for MC
    Last Post: 06-04-2008, 12:34 PM
  2. I'm a nOOb looking for a router design
    By zachjowi in forum DIY CNC Router Table Machines
    Last Post: 03-02-2008, 06:14 PM
  3. vexta PK266 motors - noob questions
    By tranceamerica in forum Stepper Motors and Drives
    Last Post: 06-28-2007, 11:26 AM
  4. Noob question
    By PBfan in forum General CAM Discussion
    Last Post: 07-06-2006, 12:19 AM
  5. noob alert: recomend a design for these steppers
    By pen25 in forum DIY CNC Router Table Machines
    Last Post: 03-02-2005, 03:31 AM
