Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 02-12-2009, 11:30 AM
behindpropeller is on a distinguished road
Compressed Air Lines
Are there any economical alternatives to black pipe or copper for running permanent air lines in a shop??
Old 02-12-2009, 12:02 PM
LaserImage is on a distinguished road
Whatever you do, don't use pvc pipe - unless you have great medical insurance and have me named as a benificiary on your life insurance...
Old 02-12-2009, 12:16 PM
Add me also, please.
There has been mention in a thread about some plastic tube that is rated for air lines using special fittings but I think the cost was no lower than copper. We use copper because it is so much cleaner and easier to install.
Here is a hint: sprinkle ball valves liberally throughout the network of airlines so that you can isolate portions to work on when necessary. This saves the embrassment of forgetting what you are doing and shutting down the entire system and having a whole lot of machines stop with no air alarms
Old 02-12-2009, 12:25 PM
I have some of that plastic tube on my laser, it's low pressure - 30psi, and low volume. It can be used for higher pressure and a larger tube would get you more volume, but it isn't going to be cheap. I think the tube I bought was about $1.00 per foot in small quantities. The fittings are not cheap either. I would have done copper but I wasn't sure of the layout of the shop and didn't want to have to redo it when I changed things around.
Gary
Old 02-12-2009, 01:08 PM
I just got back from the store and compared copper with black pipe. Copper is probably 20% more costly due to the price of the fittings. I was thinking 3/4" copper or 1/2" black pipe. I did not find any copper fittings that would go from a 3/4" copper to a 1/4" NPT.
Why do you guys say copper is easier than black pipe? Soldering seems to take more time than screwing black pipe together.
I already read the thread on PVC pipe for airlines so I will heed the warning and drop that idea.
Old 02-12-2009, 01:56 PM
Originally Posted by behindpropeller View Post
....I did not find any copper fittings that would go from a 3/4" copper to a 1/4" NPT.
Get 1/2" and just use a reducing bushing down to 1/4"NPT.
With black pipe you need to cut and thread the ends then screw everything together and it is difficult to adjust the lengths that you get wrong.
With copper you simply cut, deburr, clean and apply flux and assemble nearly all the piping before going along with the propane torch and soldering all the joints. It is very simple to trim the pipe lengths in position for your fit and you can spring the pipe into position easier.
And you don't get your hands as dirty.
Old 02-12-2009, 02:14 PM
And you can always count on the fitting to point in the wrong direction when it is tight - the only way to get it to point the right way is to overtighten it or leave it loose... not so with copper.
Old 02-12-2009, 04:48 PM
Andre' B is on a distinguished road
A while ago the boss finally got tired of rust and crap in the lines and replaced everything with aluminum.
Not sure what brand it was but somthing like this.
http://www.garage-pak.com/compressed...ipe/index.html
If a speedy instal is in anyway a factor it goes up fast.
Old 02-12-2009, 05:18 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
If your running air tools, go with the bigger diameter, makes a HUGE difference, especially with impacts. Industrial air fittings, but I think they are 3/8" NPT. Even if you use a reducer right at the impact gun, you'll notice A LOT more power.
MC
Old 02-12-2009, 05:52 PM
That is new to me. It certainly looks like a nice system.
  #11   Ban this user!
Old 02-20-2009, 08:02 PM
xjdubber is on a distinguished road
never read the thread on pvc pipe but were they using schedule 40? or class 200 maybe? I know here in canada the sched 40 csa is rated up to 300 psi just dont run it anywhere where there is heat of 30c or sun. I do water well pumps and treatment and have ran 200 psi on it. It also does get used on Reversed osmosis units where it is always at 200 psi. they will usually use sched 80 on that though.
  #12   Ban this user!
Old 02-20-2009, 09:34 PM
With PVC and ABS pipes on compressed air it is not so much a lack of pressure capacity but the way they fail catastrophically throwing shards of plastic all over the place at high speeds.
PVC Compressed Air lines Five-10 CNCzone Club House 47 01-07-2011 07:51 AM
matsuura compressed air? integerspin Mori Mills 0 12-19-2008 12:00 AM
Chip Removal with Compressed Air antelnation General Metalwork Discussion 4 05-23-2008 01:44 PM
Compressed air filter/regulators wildcat Metal Working Tooling 5 06-30-2007 07:29 PM
Compressed air supply required for 50A plasma.. hotponyshoes CNC Plasma and Waterjet Machines 13 04-15-2007 08:16 AM
