| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
I have a precise jig grinder model jil. it seems the bearings are going out of it. I do not know what thread to post in for help or advice on where to get it rebuilt any info is appreciated. Thanks, Chris |
CK... If you get the machine pulled down, you should be able to get the numbers off the bearings and go to a bearing company ( like, say, Motion Industries ) and they can match the bearings up for you. It'll be a whole lot cheaper than trying to go back through the machine manufacturer (if they are still in business). I have to do this with a lot of the machinery at our shop. Hope this helps you out!!! |
| NOT all of the special features needed to insure PROPER bearing interchanges are found on the bearings. Examples Preload (very critical due to speed vs stiffness issues) Radial runout (sometimes special vis use of ultra precision balls) Select fits of OD or ID. Noise qualification SPecial grease or fill. Axial runout specs yes you can get close via the "numbers on the bearing" but not always Do plan on having the ID taper reground. Failure to do so will/can result in a very unpleasant experience with tool runout/chatter that "magically appeared". Revuilding the spindle is MORE than slapping in new bearings Last edited by NC Cams; 01-26-2009 at 01:53 PM. Reason: typos |
| Are you referring to a Precise brand spindle? If so, you may want to contact Fischer Precise USA Inc. Phone number is 262/632-6173. I have no connection with them, just a long time customer. Dick Z
__________________ DZASTR |
| precise movements in mach....how do I... | cephjedi | Mach Software (ArtSoft software) | 2 | 04-04-2007 06:52 PM |
| Precise Mini Mill? | ZipSnipe | Benchtop Machines | 0 | 03-17-2006 05:47 PM |
| Precise Radius Grinding? | Otokoyama | General Metalwork Discussion | 9 | 03-05-2006 05:45 PM |
| Are ballscrews necessary for PRECISE work on a cnc lathe? | daytrader | General Metal Working Machines | 15 | 01-10-2005 12:34 PM |
