Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 01-12-2009, 12:45 PM
acecnc is on a distinguished road
Need help with Routing plastic
Hello,
This is my first post so please excuse me if I'm in the wrong forum but I didn't see a topic for plastic.
I am routing .5" HDPE Plastic that happens to need 15 holes per part x 19 parts per sheet. The hole drilling is taking about 30 mins. and every single hole drilled is causing plastic to ball up (see attached photo) on the single flute .25 flat endmill. I would like to find a way to manually drill the holes using a jig or multi-collet drill because I think it would be faster, in the meantime I'm stuck doing it this way.
My machine is set up to run at 200ipm @ 14,000rpm.
.25 single flute (spiral upcut) onsrude.
the hole is .3125 in dia.
Any advice on things to try to keep the plastic from spinning up on the bit?
Thanks for taking your time to read/respond!
Old 01-13-2009, 05:11 PM
beone is on a distinguished road
try dish detergent as a lube
In the words of the Toolman--If you didn't make it yourself, it's not really yours!
Remember- done beats perfect every time!!
Old 01-13-2009, 06:35 PM
I've tried everything else... wd40, Pam, oil and air are the ones to come to mind. I will try dish detergent....any particular brand?
I know I'm dulling tools by knocking it off with scrap plastic - it's very annoying!
Thanks for the tip!
Old 01-13-2009, 07:53 PM
dougie329 is on a distinguished road
we use compressed air when machining plastic, comes through a regulator and manifold attached to the cnc router and has a locline flex hose to put it where you need. Should solve your problem.
Old 11-24-2009, 03:44 PM
RJLDesign is on a distinguished road
Hi, just a suggestion but I'd try a faster plunge feedrate and use a peck drilling op first using you 2flute before running your nornal mill cycle to open dia. of holes.
(faster feed rates can help reduce heat build up when tool is touching plastic)
Good luck
bobby
Old 11-24-2009, 07:33 PM
judleroy's Avatar
judleroy is on a distinguished road
Try using a .3125 two flute instead of a single flute. Also try a chipbreaking bit to keep the chips that are formed small enough not to rap the tool. Try 10,000- 15,000 rpm with a .007-.012 chip load to determine feed. Judleroy
Old 11-24-2009, 08:19 PM
rowbare is on a distinguished road
Try slowing the cutter down a bit maybe 5-7000 rpm.
Help Routing MDF? lgroulx200 DIY-CNC Router Table Machines 7 09-17-2008 07:09 PM
New to cnc routing Duster360 Commercial CNC Wood Routers 6 08-15-2008 02:07 PM
Need A Quote- Plastic routing (or suggestions) depewke-cnc Want To Buy...Need help! 0 08-06-2008 10:34 PM
New to CNC Routing need some help .... Beardown DIY-CNC Router Table Machines 8 05-05-2007 09:37 AM
Q on CNC PCB Routing soundmotor DIY-CNC Router Table Machines 7 04-27-2006 06:16 AM
