Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 10-02-2008, 06:52 AM
*Registered User*
TT350 is on a distinguished road
Metal buildings
I had a 50x50x14 metal building give to me
and I am in the posses of poring a slab for it.
My question is about insulation.
The building had the standard 3” thick fiberglass with
white vinyl backing, couldn’t be saved.
I’ve recently seen buildings with a thin foil backed bubble type insulation and it seems like a 50/50 slit
on who I talk to about witch is better.
The price is about the same for either type.
Do any of you guys have any experience with one vs
the other?
I live in south MS and the summers are very hot.
Old 10-02-2008, 09:09 PM
donnelson is on a distinguished road
spend all you can on insulation its the last line of defense between you and the electric co.
Old 10-03-2008, 05:29 AM
blackbeard52 is on a distinguished road
I can contribute as i have installed both. The "double bubble" is easier to deal with as far as installation but the r factor is a little less. however, the reflective covering is better for the hot summer months and if you ever have a need to wash the walls....it is certainly better. look for the compressed type fiberglass instead of the double bubble. the cost will be about the same but usually comes with a lap seam. Lap the edge if it doesnt have the 4 inch joint as the joint tape is not going to last. Metal buildings will sweat so it makes sense to plan for it. give the building a way to drain it to the outside and seal the base trim to prevent it from leakin to the inside.
Old 10-03-2008, 07:04 AM
*Registered User*
Thank's for the heads up.
Scrap metal recycling - American scrap metal recycling Ascrap2003 Want To Buy...Need help! 0 05-05-2008 03:21 PM
Newbie- Which red metal? steele General Material Machining Solutions 7 02-25-2008 09:27 AM
First cut in metal sickpaint Syil Products 0 12-25-2007 06:17 PM
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 12:26 PM
where do you get your metal? annihilator DIY-CNC Router Table Machines 18 11-24-2004 04:28 PM
