Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 09-10-2008, 02:00 PM
woox is on a distinguished road
CNC Router LASER Engraver mod?
Is it possible to convert a CNC router to a laser cutter/engraver? I want to engrave text onto plastic so I need it very, very fine, just wondering if this was possible.
Old 09-10-2008, 04:00 PM
LaserImage is on a distinguished road
Sure it's possible. My laser uses a printer driver that allows me to adjust the speed from .1% to 100% speed, and the same adjustment for power. The speed on mine is 80ips for raster and 40ips for vector.
The biggest problem I see is configuring whatever software you use to handle speed and power settings.
I am sure others have done it though.
Gary
Old 09-10-2008, 07:21 PM
do u know where i can actually get the laser?
Old 09-10-2008, 09:27 PM
ebay is your friend!
You should be able to find an air-cooled tube for a couple thou. Stay away from the water-cooled, glass tubes, they are old technology.
G
Old 09-11-2008, 05:52 AM
Not sure what exactly to search for, but something like this?
http://cgi.ebay.com/SPECTRA-PHYSICS-...3286.m20.l1116
or
http://cgi.ebay.com/JDS-Cyonics-Unip...d=p3286.c0.m14
Old 09-11-2008, 11:48 AM
You would want a CO2 laser, neither of those would really be appropriate. You would want something at least 30 watts, more is better.
The tube is just the start of it though, you need optics as well.
I'm really out of my league giving advice on how to put one together, I bought a $30,000 laser that came ready to go. I built my cnc router, but I wouldn't even consider trying to put a laser together myself, that's just me though.
I think there is a laser forum here, I would advise you check there, they absolutely know more than I do...
G
Old 09-11-2008, 01:18 PM
Iain F is on a distinguished road
How fine is fine ? Normally a laser marking uses a scanning head to make the marks. So you would use the CNC router to position where you want to scan. How much do you want to spend on the convertion ? You can buy an off the shelve maker with all the software built into it and probably save a lot of grief.
Laser Cutter/Engraver jymmm Laser Engraving & Cutting Machines 17 10-31-2010 12:42 PM
laser engraver Stone guy Canadian Club House 0 04-24-2008 08:15 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
Laser Engraver arisking Laser Engraving & Cutting Machines 5 06-23-2007 04:39 AM
Vytec laser engraver help cmbheli Laser Engraving & Cutting Machines 2 02-24-2005 02:54 PM
