Results 1 to 4 of 4
Thread: 208oz vs 277oz Motors for CNC
    Aug 2008
    Hi i am buying a CNC router, and I have a option to upgrade form a 208oz motor to a 277oz motor for +$50. I just want to know what is the diffrence from upgrading to a bigger motor?
    I am mainly cutting plastics such as plexiglass and PVC.
    Nov 2007
    What are you planning to do with it? The questions I would have would be the leadscrews and linear rails, both of which seem homemade on this machine. I would look a little harder, maybe a K2 or fireball v90. If you are planning on using a dremel get a proxxon instead you will me much happier with it.
    Nov 2007
    $50 seems cheap for more power and speed. Plexi can be tricky to cut without melting. more power gives you more flexibility on speeds and feeds.
    Aug 2008
    Quote Originally Posted by sjoy113 View Post
    Can you recommend me a good dremel to use? I looked at the paxxons but I really dont see which model to buy in particular, any suggestions? How does the dremel 395 look?
  1. Build Thread- Building a CNC Router; by someone who can't build a CNC Router
    By Womble in forum DIY CNC Router Table Machines
    Last Post: 09-27-2008, 08:51 AM
  2. Newbie- Does anyone own a EZ Router Machine? Plasma or Router.
    By sngatlanta in forum Commercial CNC Wood Routers
    Last Post: 04-11-2008, 11:48 AM
  3. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 04:33 PM
  4. Need help finalizing plan for CNC Plasma table
    By David Bord in forum General Waterjet
    Last Post: 05-25-2005, 08:16 PM
  5. Surfcam PP for Isel router / Precix router
    By IvanTochev in forum Post Processor Files
    Last Post: 05-12-2004, 01:27 PM
