Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 09-03-2008, 12:49 AM
woox is on a distinguished road
VCARVE + xylotex ?
I am ordering a CNC machine with a xylotex controller board. My question is does/would vCarve PRO be compatible with a xylotex setup?
Old 09-03-2008, 01:11 AM
Mike Nash is on a distinguished road
I've used the older Xylotex with VCarve Pro. I was running TurboCNC at the time and using the "G Code ATC Inch (*.tap)" post processor. There's also a specific Mach2/3 post processor.
You will have to have machine controller software such as Mach 3 ($169), TurboCNC (shareware) or EMC2 (free) in addition to the VCarve Pro. The Mach 3 demo has a pretty low line count limit when considering v carving. Mach 3 needs Windows 2000 or XP, TurboCNC needs DOS and EMC2 needs linux.
Old 09-07-2008, 01:28 PM
Do you know of a driver board that would work 100% with Vcarve? I read that Xylotex was one of the best but I dont want to waste my money knowing that it does not work.
I am also using Nema23 motor's. (Here is the link to exact CNC machine I have: http://mckenzieschmidt.com/pages/hoboJrMain.htm)
I appreciate your help! (And I have Mach3)
Old 09-07-2008, 02:36 PM
ger21's Avatar
The drives have nothing to do with the software you use. The software outputs a g-code file, that your control software needs to read. You need to make sure your control software will work with V-Carve Pro. Fortunately, V Carve pro will work with just about any control software.
Old 09-07-2008, 02:43 PM
Ah thats all I wanted to know, thanks!
UPgrading From VCarve 3.1 to VCarve 4 or 4.5 Khalid Vectric 1 11-15-2007 07:51 AM
VCarve Pro 4.5 has been released. bsimages Vectric 6 11-14-2007 06:34 PM
Mach 3 + Vcarve PP = ? H2ODiver Mach Mill 25 06-13-2006 04:43 AM
VCarve and drilling spalm Vectric 4 04-10-2006 09:54 AM
