Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 08-02-2008, 12:46 PM
springlakecnc is on a distinguished road
I have an Electrical Question for Hardcore retrofitters
Hello electronic engineer,
Ok, you know about sizing servomotors to drives, and so do I (kinda).
If a servomotor is a nema42, 12 amps continuous, 35 amps peak, a 40-amp drive will work nice.
If you wire this same servomotor to a 20-amp drive, the servomotor will probably take off like a bat out of hell, but when you go to stop it, POW! THERE GOES THE POWER MOSFETS!
Whenever I do a board level retrofit, when I’m ready to test the system, I always put way undersized fuses in everything, for start-up. I did notice, sometimes you can run 3, 12 amp, 40 amp peak, nema42 motors, in a 3 axis milling machine, with a 6 amp fuse going to the power supply for all 3 axis. Meaning that most of the time, you are not drawing anywhere near the power the system could put out, maybe only for acceleration or when you crash into something.
Rutex has some interesting reading on their web site (or they used to) telling you the calculation of how to put an "in line" resistor, in one of the power lines, that will protect the drive against oversized motors and not sacrifice as much power than you may think. Rutex does say you can get away without doing anything special, if you can guaranty you will not decelerate the motor any faster than you accelerate it. But, if you’re motor goes into oscillation while tuning, or a heavy load on the mill table pushes to hard when you are stopping, or you simply crash an axis into something, BAM! Drive gone!
My question is, will this work??
Say you have that 35-amp peak servomotor, and the 20-amp drive. You wire the two power wires as you normally would, with exception of: The Armature + line, you put a 20 amp fuse, thus anything over 20 amps will blow the fuse. Now you run a second line in parallel around the fuse with the correct resistor in it. The theory behind this is, the electron flow will take the easy path through the fuse, and just bypass the resistor allowing the drive to put out 100% performance. If there is a power surge from the servomotor, the fuse blows and the resistor helps the drive sop up the braking amps, thus sparing the life of the drive! (I e mailled this to a couple of drive manufactures, and got no responce)
Any thoughts?
If I don’t get any input, someday I’m going to take a 45 amp electrocraft servomotor like on a Hurco machine, and hook it to a Gecko drive, with the 20 amp fuse & resistor, and see what happens!
This is kind of important, as MANY of the people that are building a cnc control, either don’t have the money to do it right, OR, they just don’t know the difference between “peak” and “continuous” amp ratings. I just answered a man’s questions; he bought a Hurco with a dead cnc, and was going to run the servomotors that were on the machine, with Geckos! He thought 20 amps were enough to power the motor, but he obviously doesn’t know what stops a servomotor!
Talking about undersized, I hooked my 18 volt drill motor battery to a Cincinnati 20hc2000 100”x40” travel, Ghetty’s servomotor, to jog the axis out of the way, and it worked!
Thanks All.
Old 08-02-2008, 01:24 PM
Al_The_Man's Avatar
Using a lower current rating of a drive does not run a motor any faster, as a generalization, current is torque, voltage is speed.
Using a larger motor within reason, will prevent obtaining the torque capability of the motor.
I am not familiar with the drives you quoted, but all the ones I have used have adjustable current limit feature, I have fitted larger motors to smaller drives in a pinch until I can obtain the correct sized one.
The loading has to be watched or the current limit will kick in and shut the drive output off, I have never lost a drive to this yet.
If the drive is designed right, there is no need for series resistors etc.
I always fuse the AC input to the drive PS rather than individual drives on the DC side, this can sometimes blow the drive.
Also if you stall a servo motor, it is going to offer a load that imitates a MUCH larger motor, obviously it should not blow the drive if this happens.
l.
Done that many a time with an automotive battery.
Old 08-02-2008, 03:02 PM
neilw20's Avatar
neilw20 is on a distinguished road
Where does that energy go?
If you have as motor running and it regenerates that energy has to go somewhere. If it is going through a fuse, and the fuse blows, now you end up with spare energy being turned into a higher voltage. While the fuse is blowing the plasma in the arc is quite low impedance and any extra voltage is sent back to the supply. If this exceeds the ratings (either voltage or current) of the MOSFET the fuse really hasn't protected anything yet as the plasma is still allowing current to flow.
Putting a resistor across the fuse can allow the plasma to extinguish earlier and the resistor may reduce the current to a safe value.
The voltage across the plasma may be in the order of 10-80v.
If the fuse is big enough, then any excessive current has to go somewhere or become a higher voltage. This is normally absorbed by your DC filter capacitor. Naturally if you pump up your supply to above the design rating of the drive circuitry it is a potential (no pun intended) risk.
The extra energy needs to go somewhere and if the avalanche capabilities of the MOSFETS can't handle it, then you need a DYNAMIC SNUBBER.This can take the form of a MOSFET in series with a low value power resistor that gets switched across the supply during the spike. But it not a simple as that, because you don't want the supply powering the resistor too.
This is the mechanics of it. The solution is beyond the space available (on my screen).
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 08-03-2008, 02:15 PM
CarbideBob is on a distinguished road
"Hardcore retrofitters"?
Would that be people who build strange machines for XXX movies??
I don't think your idea will work so well as it's most likely the volts not the amps that is taking out your drives. Besides what good is it if you blow a fuse every time you decel from rapid?
These amps don't have overvoltage and overcurrent protection ???
See the engineering notes on AMC's website. Also see the section on shunt regulators.
Never use a power supply voltage of more than 75% of the amps full voltage rating.
I've driven many motors with amps rated at 25% of the motors rating and I've never toasted an amp.
Bob
You can always spot the pioneers -- They're the ones with the arrows in their backs.
electrical actuator question MATCHLESS CNCzone Club House 0 08-23-2007 05:15 PM
Electrical Issue!! dak70 Machine Problems, Solutions , Wireless DNC, serial port 2 03-15-2007 09:47 PM
Electrical Interference Scratch CNC Plasma and Waterjet Machines 0 01-13-2007 11:49 AM
well the electrical part is almost done truman DIY-CNC Router Table Machines 2 08-13-2006 12:04 AM
Electrical noise. MrBean General Electronics Discussion 3 01-13-2005 07:25 PM
