| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
#13
| If side milling you could use a large cutter to eliminate any flexing. Maybe even HSS for such a small cut. I mount a 6 inch side milling cutter in my shell mill adapter. These cutters look like circular saw blades. Load/unload ergonomics is going to be the key to making money here as the cutting time is only going to be at most a couple of seconds Even how far you retract the tool is going to have a big influence on cycle time. (unless of course you've got one of those nifty 2000 IPM rapid machines) I'd look at putting a bunch of parts on the table as starting/stopping the spindle for each part is going to kill ya. This job begs for automatic loading but I'm guessing it doesn't have a lot of money in it. We hit a wall at about 300 pcs per hour when manually loading as this is about the limit one person can handle, Bob
__________________ You can always spot the pioneers -- They're the ones with the arrows in their backs. |
#14
| Geof (and others) Start with a used flywheel press (they are either really cheap or free for the taking) and 30-40k for the rest of the machine. The operators can go and do other profitable jobs when the run is done. Accounting work to be done by others - just a suggested solution. I have also made machines for parts like this that were a little slower (2-3 seconds) that did the job by broaching. You could double the time and reduce the costs by having manual load/unload.
| milling lip around bottom of item | BrassBuilder | Dolphin CADCAM | 24 | 03-12-2008 08:24 AM |
| Z-axis - mounting rails on spindle side, rather than tower side | guru_florida | Linear and Rotary Motion | 7 | 01-31-2008 06:54 PM |
| Side Milling | SKEETO | General Metalwork Discussion | 3 | 12-17-2007 06:04 PM |
| Milling flats on the side of round stock | MichaelHenry | SprutCAM | 18 | 10-21-2007 06:36 PM |
| Milling top and bottom? | bigvinney | General Metalwork Discussion | 7 | 01-28-2006 09:16 AM |
